The simplest way to connect the LinuxCNC PC to your mill is by using the PC's 25 pin printer port, otherwise known as the Parallel Port. There is a very good wizard called 'Step Conf Wizard' to talk you through the configuration of the Parallel Port. The stepper configuration details will be very similar to those you currently use for Mach 3.
