Hi Jason and All.
Rather than sully your build thread I will mention that we tried a pseudo " Desmodronic " shutter arrangement on CHUK 2.
An old friend, now departed took some cam castings to a local CNC engineering shop and had them Mill the profile about a 1/4" wide into the casting. Using a small ball race fitted at right angles to the operating rod.
This version was successfully built and run by Martin Lorenzo and was clocked at over 1000 RPM. The picture is on my website, the one with the balancing holes drilled into the flywheel.
I thought that if there were any builders with CNC capability this might be an interesting diversion to the use of a spring return system.
Kind regards, Graham.
