Author Topic: Hoglet flywheel centres  (Read 1845 times)
Offline Trevorc
« on: June 08, 2017, 09:32:33 PM »
Hello, does anybody have any hints to give on how to cut the 0.030 inch wide slot between the two 0.375 holes in the steel centres of the flywheel. Slitting saw wont go all way through and using a hacksaw seems a little crude. Any suggestions? Thank you Trevorc
Re: Hoglet flywheel centres
« Reply #1 on: June 09, 2017, 07:34:53 AM »
I used a junior hacksaw
« Reply #2 on: June 09, 2017, 11:25:15 AM »
I will check tonight. If I remember right, than I have used a 20x0,5 mm slitting saw from both sides.
The reamaining material in the center was cut away like Jason said.
« Reply #3 on: June 09, 2017, 07:16:18 PM »
... I have found a picture.
It was a 40x0,5 mm slitting saw blade with a self  made arbour.
« Last Edit: June 09, 2017, 07:44:36 PM by fumopuc »
Offline Trevorc
« Reply #4 on: June 09, 2017, 08:07:44 PM »
Thank you both for your replies. The way forward is now clear.
Regards
