Have you used the reamer on steel? Use reamers, and other cutting tools on brass first, when it starts to get blunt, then use it on steel.I'm afraid I'm chicken, I use my reamers at hand speed, and with brass don't stop, and keep it cutting, don't let it rub.Ian S C
What Ian said...and leave less stock for reaming...I usually drill, bore to .005 under, then ream. The boring operation straightens the hole and makes it round, and the reamer then follows the straight hole.
Hi Dave, I would say, a drilled hole is a hole but not with a proper round shape.If you need a round shape i.e. for rotating a shaft inside, than the result of drlling with following reaming will give a much better result.
