Really no different to the Jowitt popett valve engihe that I made a while ago except there is a rocker arm and bell crank in the valve linkages. Would be single acting eg air pushes the piston down and the momentum of the flywheel carries it back up which pushes the air out the exhaust.Would be quite simple to replicate. Just need to work out the governor, I would have thought it is set to keep the inlet closed during the miss cycle otherwise you would waste air and then open the inlet as the speed slows. Exhaust is held open while missing so air can be sucked in and out by the piston movement.
Gas Version on Smokestak and mention of the popett valve oneshttps://www.smokstak.com/forum/showthread.php?t=122320
That is brilliant! Would love to build a version of that, given plans. I found a reference to that company also being on Latta Road here in Greece (suburb of Rochester NY). Very little info otherwise.
That really does have a nice hit and miss sound to it Chuck. Hope you can fine more details on it.Bilk
Quote from: b.lindsey on May 14, 2017, 06:15:47 PMThat really does have a nice hit and miss sound to it Chuck. Hope you can fine more details on it.BilkHey Bilk! What did you do with Bill?-Bob
As there are two separate cams any overlap is taken care of by how the cams are timed in relation to each other and their duration.As you say it certainly has the right sound to it.You could send a comment to Gil via Youtube and see if he can take a few close up photos.
Oops, that's what I get for trying to type on the phone . Fortunately the gnomes are still under control.Bill
