That's a really good idea, I say that because I made one for my x2. however I went to the next step.I made a new, longer drawbar and brazed a steel collar near the top of it so it came inside the extractor body, then I made 2 brass thrust washers to go top and bottom of the collar. then I drilled out the top thread so the drawbar could poke out.
Here we go, here it is installed, note the hex end of the drawbar poking out the top.and here are the parts, dimensionally you need a few mil vertical movement of the drawbar for clearance when assembled.hope this is clear enough, any questions, just shout.Roy.
