Freefuel,
The diesel fuel injection system has always been the challenge of building a model diesel engine. The DD used unit injectors, which for those unfamiliar, are a combined fuel injection pump and injector mounted in the head and operated by the camshaft. This would be no little task in miniature. The injector plunger and bushings would have to be ground to very close tolerances to work, not to mention the fine injector holes. A valve in head two stroke spark ignition engine with blower scavenging could be just as interesting and might be doable,....and could look just like a DD engine.
Jeff
