Author Topic: Doncaster  (Read 9311 times)
Re: Doncaster
« Reply #15 on: May 11, 2017, 04:04:34 PM »
If anybody finds me buying big castings then shoot me, I'm only making things I can pick up now
Jonathan
Just make sure you don't drive there in a Forklift then!
Re: Doncaster
« Reply #16 on: May 13, 2017, 04:44:03 PM »
Someone found some castings to wind me up with
Re: Doncaster
« Reply #17 on: May 13, 2017, 04:59:15 PM »
Does it say Gold or Sold on that casting :thinking:
Re: Doncaster
« Reply #18 on: May 13, 2017, 05:12:46 PM »
Its been named Rusty  :facepalm:
« Last Edit: May 13, 2017, 05:56:37 PM by Jo »
Offline Bluechip
  • Derbyshire
Re: Doncaster
« Reply #19 on: May 14, 2017, 11:12:00 AM »
Never mind Mr. Rusty  .. What is it ???  :headscratch: Don't keep us in the dark.
Anyway, nowt amiss that a quick waft over in a shot-blaster wouldn't fix ...
I like his Power Strip. Offered several 8-gang 13A a few years ago but they were  for vertical fitting.   :(  Nearly new too.
Re: Doncaster
« Reply #20 on: May 14, 2017, 11:15:14 AM »
It is Rocking Horse do-dars = a Stuart 600. Last cast before WW2, never to be done again  :disappointed: He also has the matching set of castings for the 800  :cussing:
That is a test equipment power rail supply. They come available at work each time we dispose of another piece of kit...  ;)
P.S. He does not have a Sandhurst  ::)
Offline Bluechip
  • Derbyshire
Re: Doncaster
« Reply #21 on: May 14, 2017, 11:31:56 AM »
Wossat then  ?  :headscratch:
Some sort of blaster cabinet??  Something else entirely different ???
Re: Doncaster
« Reply #22 on: May 14, 2017, 11:57:57 AM »
It is the final of the big Stuart Gas engines 2" Bore 3" Stroke.
« Last Edit: May 14, 2017, 12:02:36 PM by Jo »
Offline Nick_G
Re: Doncaster
« Reply #23 on: May 14, 2017, 12:08:05 PM »
By the time Jo had spent considerable time fondling them instead of machining them either the gold plating or the iron oxide coating will have worn off and pristine surgical cleanliness metal will be left.  :D ;D
Nick
Offline Bluechip
  • Derbyshire
Re: Doncaster
« Reply #24 on: May 14, 2017, 01:02:00 PM »
Wow! Hefty brute ...  :)
Why are the ends of the rocker shaft split pin not turned over ??  :headscratch:
Looks like one of my sort of 'disasters in waiting'   ;D
Re: Doncaster
« Reply #25 on: May 14, 2017, 01:24:55 PM »
Has he got a 400 Jo?
I got some castings the other day, going to name the model Scabby, can you guess why
Offline Alyn Foundry
Re: Doncaster
« Reply #26 on: May 14, 2017, 01:34:23 PM »
Ah.... The mighty 600....
I own a partially built twin flywheel one that I picked up in the early 80's, really nice engine.
Allegedly modelled on a National Gas engine that drove the Stuart Turner works.
The Sandhurst was IMO grossly under flywheeled for it's bore and stroke, twin flywheels made them much tamer in running.
An old " buff " once told me that the Sandhurst had hidden complications and was designed for students at the Royal Military Academy? True? Any thoughts?
Kind regards, Graham.
Re: Doncaster
« Reply #27 on: May 14, 2017, 01:38:55 PM »
Nice one Jason!
Even the correct Hot tube chimney, so rare!
Re: Doncaster
« Reply #28 on: May 14, 2017, 01:44:12 PM »
I thought you would like that one Graham, none of those new fangled spark plugs there.
As you are about I will put a photo of the scabby casting on the castings thread, would be interested to know your thoughts on what caused it.
PS did you see that PM I sent last Sunday?
Re: Doncaster
« Reply #29 on: May 14, 2017, 01:45:55 PM »
He has never expressed a desire for one: Like you he has a fetish for large model engines  ::). It is me who is happy to do the little ones or to make them at their original scale.
