Author Topic: Lane and Bodley 400hp Corliss  (Read 61472 times)
Online sco
Re: Lane and Bodley 400hp Corliss
« Reply #15 on: May 15, 2017, 09:45:36 PM »
Why does the bore need a sleeve?
Difficult to see in the pictures but the block was cast with a core that creates steam passages in the top and bottom of the block - the sleeve is needed to seal these passages off so that the only route for the steam is via the valves into the ends of the sleeve.
Simon.
Ars longa, vita brevis.
« Reply #16 on: May 16, 2017, 07:20:26 AM »
Is that a threading insert you are using in the boring bar?
Online sco
« Reply #17 on: May 16, 2017, 10:18:17 AM »
Bggr - I hoped nobody would notice that!  That is the biggest bar I have and because the insert is full form it has a reasonable radius at the tip so with a fine feed the finish is pretty good - certainly good enough to receive the sleeve anyway.  Am thinking about a between centres boring bar for the sleeve bore though.
Simon.
Online sco
« Reply #18 on: May 16, 2017, 10:21:03 AM »
Conversation with wife:
Wife:  Are those your new castings?
Me: Yep
Wife:  Look a bit rough round the edges
Me: That's called flash and is left over from the casting process
Wife: Still look too rough to be any use
Me:  Well the final part is hidden inside
Wife:  What you mean you crack it open like a walnut?
Me:  :ROFL:
« Reply #19 on: May 16, 2017, 10:38:04 AM »
 :hammerbash: :hammerbash: :hammerbash: :hammerbash:
Offline jschoenly
« Reply #20 on: May 18, 2017, 06:59:12 PM »
Is that fly cutter like a tangential tool?  Looks interesting!
Jared
                                 Cabin Fever Expo
--- Model Engineering and Home Shop Hobbies in all Forms! ---
« Reply #21 on: May 18, 2017, 11:20:16 PM »
Me: Yep
Me:  :ROFL:
 :lolb:
Also, was at the Owls Head Transportation Museum, where the jave a compound corliss, they ran it on air for me, very nice! First time I have seen one run in person.
« Last Edit: May 18, 2017, 11:23:32 PM by crueby »
Offline paul gough
« Reply #22 on: May 19, 2017, 01:31:44 AM »
That was a sizeable lump projecting from the 4 jaw, you went nice and slow I take it? How goes the new motor on the lathe, any further issues?? Regards, Paul Gough.
Online sco
« Reply #23 on: May 19, 2017, 07:29:57 AM »
Jarad a tangential tool was what I had in mind when I drew it up, there are a few more pictures in Don's flycutter thread here: http://www.modelenginemaker.com/index.php/topic,5268.15.html
Simon.
Online sco
« Reply #24 on: May 19, 2017, 07:31:10 AM »
Slow and steady until the bore cleaned up, then higher speed for the final cuts.  No motor issues at present!
Simon.
Online sco
« Reply #25 on: May 19, 2017, 09:31:04 PM »
Bored and reamed the valve holes and difficult to see, but the holes all break evenly into the internal steam passages so the central cast core must have been pretty accurately located.
Also tapped 20 7 BA holes - only another 52 to go in this part alone!
Simon.
Offline Jim Nic
  • Buckingham, UK
« Reply #26 on: May 19, 2017, 10:00:04 PM »
I'm no expert on castings but those steam passages look  to me to have turned out well.  Here's hoping the rest of the model is as well cast.
Offline jeff l
« Reply #27 on: May 20, 2017, 02:56:23 AM »
Dennis did a great job on the patterns and the core boxes for the same .
Online sco
« Reply #28 on: May 20, 2017, 06:25:56 PM »
There was a bit of porosity in one area of the casting that will be the exhaust port but amazingly all the thread holes landed between the porosity!  After tapping 72 7BA holes couldn't resist a mock up of the cylinder block on it's feet up against the engine frame.
Simon.
« Reply #29 on: May 21, 2017, 01:04:14 AM »
Looks nice Simon!
I'm enjoying seeing you progress on the Corliss.
