Quote from: sco on November 19, 2017, 07:05:08 PM...initially was set on using a woodruff cutter but after some stern advice ended up using a Tee slot cutter which worked really nicely...So, I have a silly question. What's the difference between the T-slot cutter and the Woodruff cutter that made the big difference. They seem rather similar to me, which probably means I'm missing the finer points of both.Thanks,Kim
