Author Topic: 1/4 scale Reid Gas Engine  (Read 11706 times)
Offline jeff l
« on: April 08, 2017, 02:54:02 AM »
I got around to finish an old project a 1/4 scale Reid gas engine it's number 122 ,it's built from castings supplied by Burns and Horner . I had to take a break from the Coles' Corliss as the governor is driving me nuts .
I started this engine in 1996 and for many years it sat on the shelf because work and illness got in the way .
When finished it will have a clutch and power , which are machined ready to install .Jeff
Offline Steamer5
  • The "Naki" New Zealand
Re: 1/4 scale Reid Gas Engine
« Reply #1 on: April 08, 2017, 06:43:49 AM »
Hi Jeff,
 That's a very nice looking engine!
After all this time i bet it will be nice to see her run.
Cheers Kerrin
Offline jeff l
« Reply #2 on: April 08, 2017, 12:46:32 PM »
Thanks Kerrin , I hope it will run, I still have to figure out the what regulator I would need for the gas  .Jeff
Offline Nick_G
« Reply #3 on: April 08, 2017, 01:26:13 PM »
That is very nice.
Good looking engine that has a very nice finish.
Nick
Offline jeff l
« Reply #4 on: April 08, 2017, 02:06:16 PM »
Thank you Nick , the casting required a lot of grinding and hi fill primer, the color is darker in person the photo shows it somewhat lighter  it's 1980 Chevrolet truck Dark Carmine.Jeff
« Reply #5 on: April 08, 2017, 02:42:00 PM »
Great finish and a fine looking engine Jeff. Hope to see it running soon.
Offline jeff l
« Reply #6 on: April 09, 2017, 03:34:39 PM »
Thank you Bill
Offline 90LX_Notch
    • YouTube Channel
« Reply #7 on: April 09, 2017, 04:19:25 PM »
I'm looking forward to seeing it run Jeff.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
Offline jeff l
« Reply #8 on: April 10, 2017, 12:04:45 AM »
I have heard that this engine is cantankerous , but I suppose any gas or gasoline engine scaled down is , I'm open to any suggestions .
I made a few changes on this engine one was to make the main valve like the original , this was suggested from a builder some 20 years ago , I'll post a photo .Jeff
« Reply #9 on: April 10, 2017, 12:27:10 AM »
That is a beautiful engine Jeff, you finish work and attention to detail is superb!
I'm sure that it will run great after you get her dialed in.
Offline jeff l
« Reply #10 on: April 10, 2017, 03:43:20 AM »
Thank you Dave .
« Reply #11 on: May 30, 2017, 11:26:49 PM »
Beautiful engine Jeff, cannot wait to hear it run.
Offline jeff l
« Reply #12 on: May 31, 2017, 03:41:52 AM »
Getting closer , the clutch is almost finished and mounted.
Offline jeff l
« Reply #13 on: August 27, 2017, 02:47:04 AM »
I decided to add a governor to the Reid engine at little late but I think the engine will look better with a governor even though it does not control the gas .
First this was to add a pulley to the charging side flywheel.
Offline jeff l
« Reply #14 on: August 27, 2017, 02:49:57 AM »
next work on the governor , here is the start of the yoke .
Brad Smith designed the governor .
