Author Topic: Crankshaft journal finish  (Read 4057 times)
Offline awJCKDup
  • Central Indiana
« on: March 17, 2017, 10:45:14 PM »
Hi all, Ive been re-reading as much as I can about turning a one piece multi-journal crank. I see where a few guys have ground the journals with a tool post grinder or a substitute. My question is this: what are "acceptable" methods of finishing the crank if grinder is not available? also what grit stones? Any and all tips would be appreciated. I believe I am nearing the dreaded "Analysis Paralysis" with an some contributing "Puckeritis".
[/URL]
« Last Edit: March 18, 2017, 01:33:40 AM by awJCKDup »
Offline awJCKDup
  • Central Indiana
Re: Crankshaft journal finish
« Reply #1 on: March 19, 2017, 10:26:09 PM »
Hmmm, crickets chirping  :help:
« Reply #2 on: March 19, 2017, 10:45:25 PM »
John--I've built about 25 engines, and all of my crankshaft journals have been turned using a 3/16" wide parting off tool. No grinding was involved. ---Brian
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #3 on: March 19, 2017, 10:49:19 PM »
No replies so i'll toss in my 2 cents worth. I turn everything to about .0005 over sized and then polish in the last half thou with 320 grit sand paper. Just cut a piece a little less than twice the width you need, fold it in half, and polish in the lathe to a smooth surface. This assumes a nice finish from the tooling.
That engine looks familiar.
Offline 90LX_Notch
    • YouTube Channel
« Reply #4 on: March 19, 2017, 11:23:17 PM »
That is beautiful John.  How far along is it?
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #5 on: March 20, 2017, 12:03:25 AM »
I couldn't reply as I don't know enough. But I'm interested in finding out what you find out.
Sorry I'm no help.
Offline awJCKDup
  • Central Indiana
« Reply #6 on: March 20, 2017, 12:51:30 AM »
Brian thanks for the info.
Steve thanks, thats been my method on everything else I've built, none have been multi cylinder, so it wouldn't be too much trouble to make another crank. My feeling is If I get this made, I won't want to make another. Just trying to do it right the first time, and don't have a grinder. You've a good memory, I showed you pictures last year at NAMES.
Thanks Bob, that's an up to date pic. all internal block and head machining is done, the crank is roughed out, and the bell housing and adapter is made. Still planning on additional machining on the oil plan and I left tons of material on the valve covers, not sure what I will do there.
Zee, now we know. If Steve's have lasted, thats good enough for me, I know he's put a lot of time on his engines.
Thanks everyone
« Reply #7 on: March 20, 2017, 01:11:41 AM »
Offline Flyboy Jim
  • Independence, Oregon
« Reply #8 on: March 20, 2017, 02:16:54 AM »
John.......after seeing the picture of Steve's crankshaft, I hope you have the time to document the process of turning yours. Should be fascinating!
Sherline 4400 Lathe
Sherline 5400 Mill
Offline awJCKDup
  • Central Indiana
« Reply #9 on: March 20, 2017, 02:48:12 AM »
Jim,
My old tool buddy said I was the biggest procrastinator that he knew, personally I think he was wrong, I think I'm just lazy. So while I will take some pictures, I would caution you not to get your hopes up. I suppose knowing ones limitations is a good thing, but I'll try.
Offline awJCKDup
  • Central Indiana
« Reply #10 on: March 31, 2017, 11:20:30 PM »
Well I gave it a shot, and I'm happy with the outcome. Here's some pic's, I was so busy frettin and puckerin, I didn't get many.
[/URL]
[/URL]
[/URL]
[/URL]
Thanks for all the help
« Reply #11 on: April 01, 2017, 12:35:44 AM »
That's a great lookin' crankshaft!!  :praise2:
Offline 90LX_Notch
    • YouTube Channel
« Reply #12 on: April 01, 2017, 03:18:12 AM »
John that crank looks great.  Well done.
-Bob
Proud Member of MEM
Offline awJCKDup
  • Central Indiana
« Reply #13 on: April 01, 2017, 02:40:50 PM »
Thanks guys
Offline Nick_G
« Reply #14 on: April 01, 2017, 09:54:16 PM »
Impressed. ............. Very.  :ThumbsUp:  :)
Nick
