Author Topic: 1st I.C. build "Tiny"  (Read 76422 times)
Re: 1st I.C. build "Tiny"
« Reply #135 on: April 18, 2017, 12:56:21 AM »
Bob,
The first time I built one of these carbs I thought "there's no way this thing will work!" but it does. Looks good!
Offline 90LX_Notch
    • YouTube Channel
« Reply #136 on: April 18, 2017, 01:23:09 AM »
Thanks George.  Does the orientation of the .020 hole in the spray bar make a difference?   The hole could be parallel to the axis of the throat of the mixer body or it could be oriented perpindicular.  I assume that I would want it parallel inorder for it to draw fuel.  Arv's notes do not specify.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #137 on: April 18, 2017, 01:42:18 AM »
Good question Bob, I was assuming the same thing you were, parallel. Looking forward to the answer.
« Reply #138 on: April 18, 2017, 03:35:12 AM »
I can just hear it now: "What ever happened to ole Bill" ......................"Well ever since he discovered sewing needles, he's spending all his time over on the Quilting Forum now"!  :lolb:
« Reply #139 on: April 18, 2017, 03:49:23 AM »
Perpendicular, at least that is the way it is on my 1.5hp John Deere Stationary engine.
« Reply #140 on: April 18, 2017, 11:28:03 AM »
Actually been there, done that Jim, though it wasn't quilting it was counted cross stitch. When I was younger and the eyes were better I found it quite relaxing. Unfortunately any needles I have left over from those days though have more rounded blunt points. This application needs sharp points. Hoping to get by Hobby Lobby this afternoon :)
« Reply #141 on: April 18, 2017, 01:14:14 PM »
I put mine parallel with the axis of the throat of the carb. That way it seems to make more of a Venturi.
« Reply #142 on: April 18, 2017, 02:24:59 PM »
Thanks George!
« Reply #143 on: April 18, 2017, 03:09:40 PM »
It's surprising how many men have done counted cross stitch or needle point..............myself included.  I think it has something with the way the process works that appeals to them. One of the most famous to do needle point was Rosey Grier: https://en.wikipedia.org/wiki/Rosey_Grier I remember on a talk show he said that he's actually a gentle person.........................unless he sees someone holding a football!  :hammerbash: Or a gun if you read his bio.
PS: This needle valve project is interesting. It never occurred to me to actually use a needle for a needle valve.  :Doh:
Offline 90LX_Notch
    • YouTube Channel
« Reply #144 on: April 18, 2017, 06:47:51 PM »
Thanks Dave and George.
-Bob
Proud Member of MEM
Offline mike mott
  • Alberta Canada
« Reply #145 on: April 18, 2017, 08:29:44 PM »
Just worked through the whole thread Bob looks great loved all the set ups with the face plate and the pallet. I had not seen the pallet device before. it looks like the surface is ground and the sides milled?
Offline 90LX_Notch
    • YouTube Channel
« Reply #146 on: April 18, 2017, 09:06:37 PM »
Great to have you along Mike.
Yes, you are correct.  Only the top surface is ground.  At the time when I made it, I didn't have anything to bank it off of to grind the sides square.  Also, lengthwise it I don't think it would fit under my little Sanford grinder.  I milled pretty square directly on the mill table.  What I was after was a flat surface parallel to the bottom of the pallet.
I would call it a fixture plate, but Tom Lipton did a video and called his a mini pallet.  They've been around forever.  They are real handy.
-Bob
Proud Member of MEM
« Reply #147 on: April 18, 2017, 10:48:53 PM »
Still following along Bob.  :popcorn:
I remember Rosey. And quilting is on my 'someday' list. Odd...I was just thinking about it the other day.
Offline 90LX_Notch
    • YouTube Channel
« Reply #148 on: April 18, 2017, 11:44:55 PM »
Thanks Carl.
This will probably be a slow week for updates.  My wife is on vacation and we are spending a bunch of "qt" while the kids are at school.  I'm still going to try and get some shop time in.
-Bob
Proud Member of MEM
Offline Mosey
  • Rosemont, New Jersey, USA
« Reply #149 on: April 19, 2017, 02:07:14 PM »
I agree with comments made by others here. This is great fun watching three of these builds going on. Especially when a Benchmaster is used!  :cheers:
Which one of you guys has my old Benchmaster?
Mosey
