Author Topic: 1st I.C. build "Tiny"  (Read 76192 times)
Re: 1st I.C. build "Tiny"
« Reply #60 on: March 26, 2017, 10:24:10 PM »
That sure looks the part Bob, nicely done!!
Offline 90LX_Notch
    • YouTube Channel
« Reply #61 on: March 27, 2017, 05:40:04 PM »
Thanks Bill.
Half way there Eric.  I chucked up a piece of mystery metal, turned and threaded it 0-80.  It was then slotted with a .014 slitting saw.  Next it was cut to length and threaded into a bar with a 0-80 hole in the lathe so the nose could be rounded over.  A file was used to form the radius.
The nut is next on the agenda.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #62 on: March 27, 2017, 06:21:59 PM »
OH yeah!!! That looks very nice Bob. You are getting fancy :)
Offline 90LX_Notch
    • YouTube Channel
« Reply #63 on: March 27, 2017, 07:28:53 PM »
This way if the engine doesn't run, it will at least look nice as a static model.
-Bob
Proud Member of MEM
« Reply #64 on: March 27, 2017, 08:22:35 PM »
That's the one for Dolly  :mischief:. Saweeeet
Eric
« Reply #65 on: March 27, 2017, 08:36:09 PM »
-Bob
Oh come on Bob not defeated before we start! Look at on the positive note, yeah it's going to run if it kills me. Much better outlook don't you think?   :stickpoke:
Offline 90LX_Notch
    • YouTube Channel
« Reply #66 on: March 27, 2017, 08:53:22 PM »
Thanks for the nod Eric.
-Bob
Not defeated at all Don.  I'm definitely not the surrender type.  I usually "crank it up a notch" when things don't go right and keep trying.
-Bob
Proud Member of MEM
« Reply #67 on: March 27, 2017, 11:08:52 PM »
I enlarged your 2nd photo for a better look. Wow. Nice!!
Offline Walsheng
  • Norfolk, MA
    • Walsh Engineering
« Reply #68 on: March 27, 2017, 11:16:45 PM »
That 0-80 screw puts in perspective...WOW, that looks nice.
Did you finish it under a microscope?
« Reply #69 on: March 27, 2017, 11:58:00 PM »
You're setting the bar Bob!    :ThumbsUp: :ThumbsUp: :ThumbsUp:
Offline 90LX_Notch
    • YouTube Channel
« Reply #70 on: March 28, 2017, 01:14:44 AM »
Thanks guys.  I did not use a microscope.  I tried to use a magnifying glass but I couldn't get use to my depth perception being different.  My vision up close isn't as good as it use to be; luckily, I can still see enough detail to get by.  I'm not raising any bar.  The bar was set by George and is wayout of my reach.
-Bob
Proud Member of MEM
« Reply #71 on: March 28, 2017, 01:53:36 AM »
Hi Bob,
I've been using a headband magnifier for years. Even if you can see a part it just makes it so much easier to work on the details. I use the strongest lens which doesn't give much depth of field but it works fine.
« Reply #72 on: March 28, 2017, 01:57:31 AM »
I can't do anything small in the shop without my Optivisor.    Love it.
Offline 90LX_Notch
    • YouTube Channel
« Reply #73 on: March 28, 2017, 02:42:30 AM »
George and Dave, can that type of magnifier be used with eyeglasses?  If not, can each eye be adjusted to balance the lens?
-Bob
Proud Member of MEM
« Reply #74 on: March 28, 2017, 02:44:15 AM »
I use an optivisor too, fits over my glasses just fine. It has a headband to hold it, and it pivots down in front of your glasses. Not sure how many models they have, mine has interchangeable lenses for different magnifications. Very handy.
