Author Topic: AOG's version of Elmer's number 32 The tall vertical open column engine.  (Read 5970 times)
Offline AOG
With the Popular complete I think it's time for a new engine. More specifically it's time for one of Elmer's engines. I wanted to do something a bit more complicated so I decided to make Elmer's number 32, the "tall vertical open column engine"
Let's get started with the base. The holes for the cylinder and columns were drilled.
Then the cylinder mounting holes were tapped.
With the base done it was time to make the table. I laid it out and drilled the mounting holes. Next I chain drilled the areas to be cut out.
The chain drilled areas were cut out and cleaned up by filing.
With the table done I needed something to hold it up. I cut four bars of hex stock to length and then drilled and tapped the bottom end.
The top end was turned down and threaded 10-24.
Then it was over to the mill where where the holes for the arms were drilled and tapped.
I'll end this with the first family shot
Till next time
Tony
Offline Mike Bondarczuk
Hi Tony,
Following along to see where this road ends and hope to learn from you.
Wonderful...a new Tony build  :) and another great start on this one. You are keeping your shop busy Tony and turning out some fine work too!! Will be following along on this one too  :popcorn:
Good start Tony. I'll be following along.  :popcorn:
Offline AOG
Thanks everyone. It was a productive weekend but as we say in aviation "the jobs not done until it's documented". First up was the bearing blocks. The blocks were squared up and cut to size. Next the mounting holes were drilled.
Then the blankets were superglued together and the holes for the bearings were drilled and reamed.
Then I used the Arnoldb method of rounding the ends. A drill bit shank was pushed through the blanks. Next a series of tiny step cuts were taken to set the general shape of the curve.
Then the part was cleaned up on the belt sander until the curves were smoothed out. Then I turned a set of bronze bearings to be a slip fit in the hole. Eventually I will put them in with Locktite. That way they won't distort from being pressed in.
Next up is the crankshaft. I started by turning the boss and the outer diameter. Then I drilled the center hole.
Then the part was moved to the mill while still on the parent stock. The crank hole was drilled and tapped and the crank web were cut.
Then the crank was parted off from the parent stock. Next I cut the shaft and turned it down to fit the crank.
The shaft was pressed into the crank and then the crank was trued up in the lathe.
Next up were the parallel motion arms. Two blanks were squared up and cut to size. Then the end holes were drilled.
The forks were then milled out.
The sides were milled down to dimension.
Then I soldered the pins into the fork. I deviated from Elmer's construction method by soldering in a single pin. Here they are right out of the pickle.
Then the center was cut out and cleaned up with some hand filling. Next the ends were rounded over and set of rods were threaded at both ends.
I started to put everything together for a family shot when I realized that I had forgotten to tap the holes in the bearing blocks. With that taken care of here is the family shot.
Work is a little crazy this week so it might be a while before I can post the next update.
Thanks for looking
Tony
That was a productive weekend Tony. You are moving right along !!
You're moving right along, Tony. Looks like an interesting build. How are the plans to work with?
Offline AOG
Jim, it's an Elmer's build albeit a more advanced one. At this point they are pretty much a known quantity to me. The only thing that's new for me is the cylinder process. There is some silver soldering required but nothing that looks to tricky. After the P&W you should be able to pull this off easily on your Sherlines.
Tony
That was quick.
I enjoy seeing Elmer engine builds.  :ThumbsUp:
Offline AOG
It's time for an update. Not a lot accomplished last week. I spent the whole week working on the cylinder and it kicked my tailpipe. I started by squaring up the blank. Then I drilled the exhaust port.
Then the port side was milled out.
Next I drilled the mounting holes for the valve chest.
I went to go tap the holes and I realized that I had misread the chart and drilled the holes clearance size. So it was back to the mil where I drilled out the holes, plugged them and redrilled and tapped them. Then the part was taken to the lathe. Where one end was turned round.
Then the cylinder was bored and reamed.
I went to lap the cylinder when I screwed up the adjustment of the lap at it seized in the bore. I had to drill it out and reream and lap the cylinder. The part was flipped in the chuck and the other end turned round.
Then it was over to the mill where I drilled and tapped the ends.
Next I milled the port slots into each end of the cylinder.
Now for the part I was dreading, the angled cuts to the port faces.
......and I botched one. I ended up cutting into the exhaust passage on one side. I ended up plugging the exhaust hole and re drilling the passage and the ports. Next I cut the cylinder flats down.
.....and I botched that task as well. While cutting one side, I didn't tighten the vise enough. The part moved and I dug into one of the rounded ends and exposed one of the mounting holes. After a long break and some thinking I think I found a way to save the part. The functional parts of the cylinder are still good the issues are cosmetic. Alternate plan c is to not round over the rest of the cylinder but to lag it with some mahogany strips instead. I'll do that part when I do the fettling and finishing. Here's the final part.
Till next time
Tony
That's a bummer you had issues Tony.  :wallbang: There's definitely days like that. However alternate plan "C" sounds good.
Offline AOG
Life is conspiring to interfere with my machining time but I did get a little bit done. The first thing I made is the bottom cylinder cover. I started by turning the boss.
Then the piece was parted off and cleaned up.
Next it was over to the mill where the mounting holes were drilled.
The second part was the cylinder top cover. First the profile was turned.
Then the gland was drilled and tapped.
The cover was parted off and reversed in the chuck. Then the part was faced and the boss put in.
Next it was over to the mill for drilling the mounting holes.
The final part was the valve chest. A blank was squared up and centered in the four jaw. The closed end was turned and given a decorative end.
The part was reversed and the spindle end turned.
Next the end was drilled and threaded.
Then it was over to the mill where the mounting holes were drilled and the center section chain drilled.
Next the waste was cut out of the center and the resulting hole cleaned up by filing.
The part was then turned over and the intake was drilled and tapped.
I'll end this with a current family shot.
Till next time
Tony
Offline AOG
Time for another progress update. Lots of little pieces this time. The next parts to be made were the valve plate and valve chest cover. The blanks were glued together and then squared up. The four mounting holes were drilled and then the parts were separated. The port holes were then drilled in the valve plate.
Next up was the valve itself. This was made from a piece of brass off cut that was squared up. Then the pocket was milled out.
 It was then flipped over and the slots were cut.
Next up is the valve rod. It was turned to dimension by turning down it down in .2 inch increments (it was to small for any of my centers) and then blended with some crocus cloth.
Then the intermediate section was threaded.
The part was moved to a collet block in the mill where the end was trimmed and the hole drilled.
The piece was parted off and put back into the collet block. Then the slot was cut in the mill.
Next up were the pack nuts. Hex stock was drilled, and turned to shape.
Then they were threaded and parted off. Next up was fabricating the eccentric strap. I started by drilling and reaming a piece of brass bar to the size of the eccentric.
Then the ring was parted off and notched to take the rod.
The rod was laid out and the end drilled.
The sides were then milled to a taper and the end rounded on the belt sander.
The two parts were silver soldered together and then pickled. Here is the result after some cleanup.
The last part for this update is the eccentric itself. I trued up the stock in the four jaw and drilled the center hole.
Then the offset was put in and the eccentric turned to fit the strap.
The eccentric was parted off and then drilled and tapped for a setscrew.
That completes this update. Till next time
Tony
Good to see your progress Tony. Nice looking parts too!!
Good work on the "fiddly bits" Tony.
