Author Topic: Metal treatments  (Read 1807 times)
Offline Barneydog
Metal treatments
« on: March 05, 2017, 03:59:21 AM »
Hi,
I have just got my Simplex running gear working on air though it will need some slight adjustment. Now it is running I am going to strip it all down to clean, smooth and fettle all the rods to get them to their final finish. The ends of all the rods and the pins all need case hardening. I am going to nickel plate them all so they are all the same colour and resist rusting. My question is do I case hardening before or after nickel plating. Case hardening requires heating to a high temperature then dropping into case hardening powder. My nickel plating kit involves a degreasing solution then suspending in warm nickel plate solution for a few minutes.
If I plate first will the plating be destroyed by the high temperature of case hardening?
If I case harden first will the plating be effective in the hardened areas?
Any ideas please?
Julian
Offline Thor
Re: Metal treatments
« Reply #1 on: March 05, 2017, 05:05:03 AM »
Hi Julian,
 When case hardening you are trying to get more carbon into the surface of the steel, I am afraid the nickel plating will prevent the carburising. So I would case harden first, then nickel plate.
Thor
Offline Barneydog
« Reply #2 on: March 07, 2017, 08:58:37 PM »
Many thanks. Harden then plate it is.
Julian
Offline Barneydog
« Reply #3 on: March 25, 2017, 10:22:51 PM »
Hi guys,
Simplex now striped and all rods etc all cleaned up. I have case hardened all the bits that needed doing but............Nickel plating does not like the high carbon content so has a mottled finish. Need to either stay with the 'weathers' look or paint them all.
Julian
Offline Barneydog
« Reply #4 on: March 27, 2017, 10:54:41 PM »
Not happy with the nickel finish so borrowed the zinc plating kit from my mate Rich.
Julian
« Reply #5 on: March 27, 2017, 11:10:46 PM »
Pics please. Otherwise my imagination runs wild.  ;D
Offline Barneydog
« Reply #6 on: April 03, 2017, 10:11:28 PM »
Took some pics but not on photobucket yet.
Abandoned metal treatments and gone with painting. Primer them all and then sprayed with a spray enamel from Halfwords. Look ok. Will refit after brakes have been made and fitted.
Julian
