Author Topic: Expo update 2017  (Read 8188 times)
Offline PTsideshow
Re: Expo update 2017
« Reply #15 on: March 20, 2017, 09:13:53 PM »
Will wait till end of week ;)
« Reply #16 on: March 20, 2017, 10:48:27 PM »
I'm planning to come but unsure of whether driving or flying.  If flying I'll have only 1 or 2 small engines.  Driving I'd have 2 larger ones as well.
Offline PTsideshow
« Reply #17 on: March 25, 2017, 09:54:38 AM »
Stan so how many tables do you want 3or 4?
« Reply #18 on: March 25, 2017, 11:31:03 AM »
Decide to fly up for the weekend.  Just need room for two engines, 1 air connection.  Plane leaves Sunday at 5 so I will have to leave early.
« Reply #19 on: March 25, 2017, 12:08:32 PM »
Stan,
I'll be there reasonably early Friday so I should be able to get a table next to wherever the group is if you run out of room. I could use one whole table myself but if that isn't doable I'm sure we can work something out.
Offline sshire
    • LS Editions
« Reply #20 on: March 25, 2017, 12:25:02 PM »
Based on the replies, 4 should do it.
Thanks again. I'll be there when the doors open on Fri for setup.
Best,
Stan
Offline PTsideshow
« Reply #21 on: March 25, 2017, 01:03:36 PM »
Ok Stan will pass it on, 4 for U!
glen :pinkelephant:
« Reply #22 on: March 25, 2017, 04:17:31 PM »
Boys, y'all just don't know how hard I'm working towards getting there. I won't need any space, but, I'll be glad to tend anybody's display while they shop or whatever. The banner is still in good shape isn't it Stan? I'll get us some table candies like many set out.
Eric
Offline jeff l
« Reply #23 on: March 26, 2017, 12:09:02 AM »
I plan on making the trip but haven't decided if I will put anything on display ; if I do what size are the fittings on the compressed air  manifold ? Jeff
Offline PTsideshow
« Reply #24 on: March 26, 2017, 10:32:01 AM »
Petcocks are standard 1/4" female NPT :cartwheel:
Offline jeff l
« Reply #25 on: March 26, 2017, 03:13:18 PM »
Thank you
Offline gldavison
  • Tarkio, Mo.
« Reply #26 on: April 02, 2017, 10:44:02 PM »
I do plan to be there again. a little over half a table should do for me.
Gary
Windows 10 & 11, Alibre Design Pro V27, IntelliCADPro6, CamBam, Mach4, 3D Printers, Cetus, Anet ET5 X
15" South Bend, 10" Logan lathe, Grizzly square column mill, CNC router & Hot wire cutter. Lagun FTV-1 knee mill, Sherline mill & lathe
Offline jeff l
« Reply #27 on: April 17, 2017, 09:23:39 PM »
I pulled my #1 out so I could take it to NAMES  and found too much play in the main bearings , years of running at shows have taken their toll I finished this engine in 1998 .
 A quick skim off the bottom of the caps and a line ream she should be ready to show .
Offline PTsideshow
« Reply #28 on: April 20, 2017, 10:53:19 AM »
Set up is almost complete . Vendors will start off loading at 3:pm today.
Offline sshire
    • LS Editions
« Reply #29 on: April 20, 2017, 02:03:03 PM »
I'm here. See you all tomorrow morning.
Best,
Stan
