Author Topic: bonding.attaching ptfe bearings  (Read 2715 times)
Offline kev
  • Portsmouth UK
« on: February 26, 2017, 07:58:33 PM »
Im wanting to make a propshaft with ptfe bearings for a long endurance voyage.
Anyway to bond them into a brass tube or maybe its best to press fit them and drill after fitting?
any thoughts guys?
Offline Bluechip
  • Derbyshire
Re: bonding.attaching ptfe bearings
« Reply #1 on: February 26, 2017, 08:19:12 PM »
any thoughts guys?
Ah ... Funnily enough ....
I had this thought that it cannot be glued. Then about 2 years ago a friend from  R.R. sez you can by using ordinary Cyano. but with this primer first.
http://uk.farnell.com/permabond/polyolefin-primer/coating-bottle/dp/2564775?ost=permabond+primer&selectedCategoryId=&categoryNameResp=All&searchView=table&iscrfnonsku=false
( Get a good grip on your chair before you see the price ...  ;D )
The PTFE I have/had is white in colour and he put a bush in alloy  for me ...  :cheers:
AFAIK it's still in there  :ThumbsUp:
Seen the price ???
Press and drill/ream it is then eh ??????  :lolb:
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #2 on: February 26, 2017, 10:36:35 PM »
Press fits don't work well with PTFE.  It cold flows (crereeps) under pressure so does not make a good mechanical joint.
The best way I came up with was to turn a series of shallow grooves in the PTFE and then cut a few grooves length wise connecting these grooves.  I think I did 0.02 wide grooves spaced about 0.05 apart and about 0.005 or 0.010 deep. This was years ago on some bushings.
I roughed up the inside of the hole and then used epoxy to hold in place.  The epoxy does not stick to the PTFE but flows into the gooves and makes a mechanical joint.  The circular grooves keeps it from pushing out and the length wise grooves keeps it from turning so you can machine it if necessary.
Gail in NM
Online Dave Otto
« Reply #3 on: February 26, 2017, 10:50:51 PM »
Many years ago when I was an equipment maintenance tech in a PC board shop; we needed to bond some PTFE strips to the stainless steel frame work where the conveyor chain ran inside of a PC board cleaning machine. We used Tetra Etch to prep the strips and Black Max to bond them in place; the Black Max is a toughened CA glue.
http://www.polytetra.de/en/products/special-products/tetra-etch-r-fluorocarbon-etchant.html
Offline old-and-broken
  • Near Houston, TX
A journey of 1000 miles begins with the first step.
