Author Topic: bonding.attaching ptfe bearings  (Read 2738 times)
Offline kev
  • Portsmouth UK
« on: February 26, 2017, 07:58:33 PM »
Im wanting to make a propshaft with ptfe bearings for a long endurance voyage.
Anyway to bond them into a brass tube or maybe its best to press fit them and drill after fitting?
any thoughts guys?
Offline Bluechip
  • Derbyshire
Re: bonding.attaching ptfe bearings
« Reply #1 on: February 26, 2017, 08:19:12 PM »
any thoughts guys?
Ah ... Funnily enough ....
I had this thought that it cannot be glued. Then about 2 years ago a friend from  R.R. sez you can by using ordinary Cyano. but with this primer first.
http://uk.farnell.com/permabond/polyolefin-primer/coating-bottle/dp/2564775?ost=permabond+primer&selectedCategoryId=&categoryNameResp=All&searchView=table&iscrfnonsku=false
( Get a good grip on your chair before you see the price ...  ;D )
The PTFE I have/had is white in colour and he put a bush in alloy  for me ...  :cheers:
AFAIK it's still in there  :ThumbsUp:
Seen the price ???
Press and drill/ream it is then eh ??????  :lolb:
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #2 on: February 26, 2017, 10:36:35 PM »
Press fits don't work well with PTFE.  It cold flows (crereeps) under pressure so does not make a good mechanical joint.
The best way I came up with was to turn a series of shallow grooves in the PTFE and then cut a few grooves length wise connecting these grooves.  I think I did 0.02 wide grooves spaced about 0.05 apart and about 0.005 or 0.010 deep. This was years ago on some bushings.
I roughed up the inside of the hole and then used epoxy to hold in place.  The epoxy does not stick to the PTFE but flows into the gooves and makes a mechanical joint.  The circular grooves keeps it from pushing out and the length wise grooves keeps it from turning so you can machine it if necessary.
Gail in NM
« Reply #3 on: February 26, 2017, 10:50:51 PM »
Many years ago when I was an equipment maintenance tech in a PC board shop; we needed to bond some PTFE strips to the stainless steel frame work where the conveyor chain ran inside of a PC board cleaning machine. We used Tetra Etch to prep the strips and Black Max to bond them in place; the Black Max is a toughened CA glue.
http://www.polytetra.de/en/products/special-products/tetra-etch-r-fluorocarbon-etchant.html
Offline old-and-broken
  • Near Houston, TX
A journey of 1000 miles begins with the first step.
