Author Topic: fitting a 3 jaw chuck to a rotary table  (Read 3061 times)
Offline Firebird
  • East Midlands UK
« on: February 26, 2017, 11:50:40 AM »
hi
I want to fit a 4" 3 jaw chuck to a 4" rotary table. It looks like the only way is to get a front mounting chuck unless anyone knows of a way to attach a rear mount chuck  :noidea:
Rich
Offline Allen Smithee
  • Mordor, Middle Earth
Re: fitting a 3 jaw chuck to a rotary table
« Reply #1 on: February 26, 2017, 12:30:02 PM »
Perhaps make something that looks like this:
(with a spigot on the back to register into the bore of the rotary table)
€0.07 supplied,
AS
« Reply #2 on: February 26, 2017, 12:42:43 PM »
I have just finished solving this problem. I purchased a M14 x 1 adaptor for my 80mm RT and then made a backplate to suit my 3 and 4 jaw SC chucks (and the 4 jaw independent).
I looked at the possibility of making an adaptor with slots where I could slide the T nuts in but they generally interfered with the fixing studs for the chucks. This set up means I can put an M14 x 1 to MT2 adaptor in the lathe and transfer the chucks between the RT and the lathe.
Offline Firebird
  • East Midlands UK
« Reply #3 on: February 26, 2017, 04:12:19 PM »
Hi
Allen and Roger.
I have one of those Myford adapters which works ok but...............
It raises the height quite a bit, adapter then backplate then chuck.
I had problems with the chuck unscrewing itself when a back and forth operation is used.
I would like to fit a chuck directly to RT if poss.
Rich
« Reply #4 on: February 26, 2017, 08:25:53 PM »
I did also look at making a centering stub for the chuck and then using some very long T nuts that hung outside the rotary table along with normal milling clamps to hold the chuck directly on the rotary table.
If I am doing a job where unscrewing is a risk I am planning to add a clamping screw to the back plate.
Offline Firebird
  • East Midlands UK
« Reply #5 on: June 10, 2017, 08:56:50 PM »
Hi
Sorry its been so long completing this, other things seem to have taken my interest but now I need to use so needs must
Here's how I did it
2 steel plates 4" dia. 2mm thick. 1 steel plate 10mm thick. All 3 are drilled centrally 8mm
1 of the steel plates has 4 x 8mm slots machined and the other has 3 x 8mm slots machined. The plate with 3 slots has an 8mm nut welded on
All 3 are bolted together through the central hole then 2 more holes are drilled 4mm and fitted with M4 socket head screws and nyloc nuts
3 x 8mm bolts fit the adapter to the chuck
then 4 x 6mm bolts and T nuts fix it to the roary table
Rich
Online sco
« Reply #6 on: June 10, 2017, 09:04:03 PM »
I understand why you used 2mm sheet to keep the height down but isn't it going to be too flexible?
Hoping to be proved wrong!
Simon.
Ars longa, vita brevis.
Offline Zephyrin
  • near Paris, France
« Reply #7 on: June 11, 2017, 09:49:52 AM »
I do have a rotary table with three T slots, hence the three jaws chuck can be bolted directly to the RT, with a set of 3 specialy made bolts, with several cross holes in their head to insert an a hardened steel rod for the screwing. In principle the centering is automatic, but I also added a centering peg, which also allows the recovery of tooling fallen in the central hole !
The problem was to mount the 4 jaws chuck...an intermediate 12 mm thick plate was the only way to fix it with my set of bolts.
« Last Edit: June 11, 2017, 09:55:46 AM by Zephyrin »
Offline Jim Nic
  • Buckingham, UK
« Reply #8 on: June 11, 2017, 11:19:24 AM »
Simon, I would think that clamping the plates to the chuck and table, which are both rigid, would reduce the tendency for them to flex and there probably isn't a lot of upward force on the chuck to counter anyway.
Offline Firebird
  • East Midlands UK
« Reply #9 on: June 11, 2017, 02:08:39 PM »
Hi
Finally before tightening the 7 bolts I have got it running as true as possible, within.002"
It is rock solid.
I have another rotary table which has a 2MT in the centre and takes an adapter for my Myford chuck. This method doe's have some flex in it and I have had the chuck uncscrew
Rich
Online sco
« Reply #10 on: June 11, 2017, 05:51:09 PM »
Good stuff!  :)
Simon.
Offline Firebird
  • East Midlands UK
« Reply #11 on: June 25, 2017, 03:03:50 PM »
Hi
Having successfully mounted the chuck I have the same problem as I had on my X1 mill
http://www.modelenginemaker.com/index.php/topic,3797.msg68969.html#msg68969
Very little room between rotary table and drill chuck.
So I have carried out the same mod as the X1.
Fly cut a lump of ally and drill 4 10mm holes
The extra 50mm in height makes a massive difference
Rich
