Jo,That Swan is going to be a monster can't wait to see it running - any idea what it weighs ?
Thanks Peter,The 5A is the single cylinder, the Swan is the double version of the 5A shown in that video. I am building one of each .That video shows all of the condenser stuff on the end of the engine but as it never really worked I won't be fitting it Jo
No not much at all.I think the Non Condensing Cygnet and the 5A were basically the same except the Cygnet did not come with the sub base as it was expected to be mounted in a hull and came with the disc flywheel as standard.The 5A was available with the disc wheel in place of teh spoked one if required.Weight of the Swan as Jo is building it is 23.5kg (52lbs). 32.5kg if it had all the pumps etcIf you ask Jo nicely she may show you a photo of her suppliers Commander which IS big
And the next engine would be???
Quote from: b.lindsey on November 29, 2017, 11:52:53 AMAnd the next engine would be??? Sitting on the dining room table Jo
