Did you just do a quick waft to remove the tight bit and let the cut wash out, 'cos I wonder why there's no packing under the trunk guide ??
New car Mine is 14 years old and its replacement will have to wait for my retirement Whoever bored these did them with feet on the face plate and a long boring bar. So on the outside they bored correctly but it went smaller on the way through. Then at the far end there was much more metal to take off so the bore had a marked reduction. The No 5 only required about 25mm the bit at the far bottom (the end I was boring from). The Second of the Swan cylinders was not so tapered (except the first 25mm again) but I wafted the full length of the guide to get the running area within acceptable limits. Tgs has stops on his power feeds in all 3 axis and all in both directions Jo
