Thanks guys, let's just say that as much as I love my Sherlines, I m definitely smitten with the Cowells now too
Quote from: b.lindsey on February 20, 2017, 11:45:32 AMThanks guys, let's just say that as much as I love my Sherlines, I m definitely smitten with the Cowells now too Bill:I'm looking forward to a comparison of the Sherline and Cowells. What do you get for the dollars.Thanks.Hugh
Quote from: Hugh Currin on February 20, 2017, 03:39:25 PMQuote from: b.lindsey on February 20, 2017, 11:45:32 AMThanks guys, let's just say that as much as I love my Sherlines, I m definitely smitten with the Cowells now too Bill:I'm looking forward to a comparison of the Sherline and Cowells. What do you get for the dollars.Thanks.HughI am also, Hugh. This is a great experiment..............especially since its Bill's dollars doing the experimenting! Jim
OK guys, with all that we have done with the Sherlines over the years, there is no question that they are great little machines, well supported and with lots of useful accessories. If one of my Sherlines weny belly up today, I would not hesitate to replace it with the same, though I might opt for the longer bed lathe this time. I had said early on that I really couldn't justify the Cowells based on needs alone, but I wanted one and bought it and I don't regret that at all. Are there differences....yes!!! The Cowells is all steel for one thing, and more rigid for its size. It has "real" gibs and they are adjusted as is done on larger lathes with set screws and lock nuts. The head gearing is down right beautiful as well as functional with longitudinal feed and threading (metric only via change gears) built in which is not the case with the Sherline. It is also reversible, though as Marv correctly points out on occasion this can be an issue with a threaded chuck unless one is careful. Think of it as a Chevy vs. a Cadillac. Both will get you where you want to go, one might make the journey a bit smoother. As I have said already the "feel" of the Cowells is noticeably superior and it is more rigid overall in my opinion. That doesn't mean there aren't some downsides thought. The Cowells does not have headstock roller bearings and is therefore more critical as to regular and proper lubrication. Accessories while available are far more limited than with Sherline. And then there is the cost differential.Would I buy the Cowells again now having played with it for a couple of weeks. Definitely!! But as noted I will replace my Sherlines with new Sherlines too if and when that is needed. Honestly I wish there was something in the middle range between both brands, but those days are behind us I suspect. We simply don't have as many choices these days as we once did, the old Emco Maier smaller lathes for example, like the Compact 5. As you guys show time and again, it has far less to do with the machine itself though than the machinist. Bill
It is real nice to use a "highest quality" tool which the Cowells seems to be. In your hands both the Sherline and the Cowells are making excellent parts.
