Author Topic: Another Tiny IC Engine  (Read 66034 times)
Re: Another Tiny IC Engine
« Reply #15 on: February 19, 2017, 03:04:02 PM »
Thanks George. I am sure a few things will come up as I get into it more and I won't hesitate to ask.
Offline Flyboy Jim
  • Independence, Oregon
« Reply #16 on: February 19, 2017, 03:20:20 PM »
Good start, Bill. I'll be following this build closely.  :popcorn:
That's a really nice micrometer you have there (insert secret handshake emoji here.........wink wink)!  :naughty:
Sherline 4400 Lathe
Sherline 5400 Mill
Offline Zephyrin
  • near Paris, France
« Reply #17 on: February 19, 2017, 03:23:38 PM »
Gail inNM
Ten of them are earning a living in Gauge 1 locomotives,
Where could I see these locos ? at last one of them !
for a change from live steam G1, I'm just planning to build a diesel "look alike" loco with one of these fabulous tiny engine !
FM
« Last Edit: February 19, 2017, 06:42:18 PM by Zephyrin »
« Reply #18 on: February 19, 2017, 05:06:26 PM »
After parting off, it was back to the Cowells to chuck the cylinder by the small end and face off the large end to the correct length. The nearly finished cylinder is shown in the last photo.
I will get back to the flywheels tomorrow...
That lathe tool looks like it's Lethal sharp!...   Good man!
« Reply #19 on: February 19, 2017, 10:28:44 PM »
Dave, thus far I have been using Warner HSS inserts, except for the grooving tool I ground up. I love the Warner tooling  :Love:
Made a bit of progress today, started on one side of one of the flywheels and it went fine (photos 1 & 2...it alctually cleaned up to look better than the pictures show), just kept looking over my shoulder at the little Cowells and it was saying "use ME, use ME," so I changed over and got the muffler made. Unfortunately I was having so much fun I didn't take a lot of pictures but I did get that part finished up. Photo 3 if the bottom end with the mounting stem, photo 4 is the top end and has a very thin wall. I did use the sherline for tapering as the set up worked out better. With the two pieces mated, I set up the rotary table vertically and stepped around to put two rows of holes in the side of the muffler as George's plans call for )photos 5 & 6. Photo 7 shows the finished up muffler less a bit of polishing.
« Reply #20 on: February 19, 2017, 10:32:16 PM »
With that done, I cleaned up the blank for the cylinder head and turned down the bottom for a nice fit in the cylinder bore. Finally the last picture is the head atop the cylinder. There is still a lot to do on the head but its a start.
« Reply #21 on: February 19, 2017, 10:43:41 PM »
The head and muffler are looking great!
Offline 90LX_Notch
    • YouTube Channel
« Reply #22 on: February 19, 2017, 10:45:33 PM »
Wow Bill you are rolling right along at lightning speed.
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #23 on: February 19, 2017, 10:57:10 PM »
And how would you compare your progress today to other days?  :thinking:
I'm thinking that new machine is driving you.  ;D
Looking very good Bill.
« Reply #24 on: February 19, 2017, 11:11:08 PM »
Not lightning speed no, but I really am enjoying getting to know the new machine. As you can tell the sherlines are not getting lonely either though.
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #25 on: February 19, 2017, 11:23:53 PM »
Looking good Bill  :)
I'm interested in the way you cut the flywheel recesses on the mill, up till recently I only had a lathe but now I have a mill and rotary table I've thought of using your method.
Any reason you didn't do the whole job on the lathe ?
Peter
« Reply #26 on: February 19, 2017, 11:28:37 PM »
Now let's see: both you and Jo own Cowells and both you and Jo have multiple builds in progress: is there a pattern here?  :Jester:. Seriously, looks as if the little fella is doing a great job. +1 on the Warner tooling. Their carbide inserts are great on stainless and their HSS even makes the hardware store stock turn nicely. Just think, spring break is just around the corner.
Cletus
« Reply #27 on: February 19, 2017, 11:43:08 PM »
Peter, I have done others this way and feel like I can be more precise with the rotary table though it is still tedious. Whatever this material is, it isn't cutting that well but I will press on. The spokes will need to be done on the RT as well. Mostly its builders preference I think and the lathe can do a good job on it too, I may even give that a try and compare the two method directly.
Cletus I know...and I have been acquiring a few casting sets along the way too though still WAY behind Jo.
Offline Gas_mantle
  • North Yorks - UK.
« Reply #28 on: February 19, 2017, 11:46:26 PM »
Cheers Bill it's something I'll try next time  :)
I'd be interested it goes when you start on the spokes too.
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #29 on: February 20, 2017, 12:35:58 AM »
Looking great Bill. You are moving right along.
To answer Zephyring I have added some links wrapped in code so as to not disturb your fine thread any more than necessary.
Since you are in France this might interest you.  Of the 1700 of these  Baldwin Mechanical built all but 10 were sent to France duringWW1 where they were used as trench locomotives. Link is to album.  Feel free to look at my other albums, in particular the Woolwich alblum.
Code: [Select]
http://s338.photobucket.com/user/NMSteam/library/Baldwin?sort=4&page=1
[youtube]VJs_zkQqPfA[/youtube]
Gail in NM
