Author Topic: Turning a Crankshaft  (Read 10567 times)
Re: Turning a Crankshaft
« Reply #15 on: February 17, 2017, 08:37:10 AM »
Seeing the HP and LP marked on the crankshaft does it have different throws or journal diameters for each?
They are different spacing's from the end of the shaft and the drawing shows the HP leads the LP by 90 degrees... ::)
« Reply #16 on: February 17, 2017, 10:17:44 AM »
Metric sizes on a Stuart drawing, whatever next :ShakeHead:
« Reply #17 on: February 17, 2017, 10:20:05 AM »
 :headscratch: That's a Reeves product/drawing designed by David P.
Stuarts do a smaller engine = 6A
Offline Alan Haisley
« Reply #18 on: February 17, 2017, 07:32:18 PM »
About how much did that billet weigh? It seems a monster.
« Reply #19 on: February 17, 2017, 08:09:54 PM »
I was told 60Kgs.
« Reply #20 on: February 17, 2017, 08:17:57 PM »
That sounds a bit much, assuming it started out as 4" bar then it would need to be just over 3ft long to weigh 60kg :thinking:
60lbs would be nearer the mark
« Reply #21 on: February 17, 2017, 09:03:42 PM »
Slippery slope Jo!     Steam launches are optimized to consume vast quantities of money!!!
"Thar be dragons!!!!!!"
« Reply #22 on: February 17, 2017, 10:30:04 PM »
You are making a crankshaft for an engine you don't have castings for??
Dave, you must have missed my comment that it was not Jo's workshop.
Muddled Engineer is making the crankshaft
Will he have it finished for tomorrow Jo?
Yes I did miss it; sorry about that.
« Reply #23 on: February 17, 2017, 10:34:09 PM »
THAR BE DRAGONS!!!!!
« Reply #24 on: February 18, 2017, 01:14:06 AM »
It started at 4 1/2" or 120mm dia, 750mm long. - Cubify calculates it out at 61.23Kg or 66.68Kg.
« Last Edit: February 18, 2017, 01:20:43 AM by Jo »
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #25 on: February 18, 2017, 01:45:29 AM »
I'd be curious to know what the finished item weighs, there must be 30-40kg of swarf to make to yet :o
« Reply #26 on: February 18, 2017, 07:57:39 AM »
I was going by the fact the ctr holes are more than half way to the edge to get my 4" dia
At 750mm long that would make Eric's mill table about 2ft front to back as there is only 4-6" hanging off the front :headscratch:
I'd say 450mm long max. You should know that some chaps like to exagerate the length of things :LittleDevil:
« Last Edit: February 18, 2017, 08:32:20 AM by Jasonb »
« Reply #27 on: February 18, 2017, 08:14:08 AM »
Folks......the weight calculation  :happyreader: for the crankshaft is just the individual cranks+journals totals = mass & is simple
However from an engineering/metallurgical point, it would be interesting to understand the Grade of the steel billet.........
Derek
« Reply #28 on: February 19, 2017, 07:47:52 AM »
Having seen the crankshaft in the flesh yesterday I can confirm that it is indeed only 400-450mm long.
And the 60kg weight quoted included the rest of the bar that the billet was cut from :lolb:
The full set of castings for this engine were last seen being loaded into the boot (trunk) of Jo's car, your guess is as good as mine what happened to them after that :LittleDevil:
« Reply #29 on: February 19, 2017, 07:59:57 AM »
 :thinking: Maybe I should start a thread about making a vertical engine.
