Author Topic: Bugatti Typ 50 1/4 Scale model  (Read 74903 times)
Online sco
Re: Bugatti Typ 50 1/4 Scale model
« Reply #285 on: December 06, 2018, 12:56:41 PM »
Great work Michael.  The tool post grinder - any more pictures of that, what you use it for etc.
Simon.
Ars longa, vita brevis.
Online Vixen
« Reply #286 on: December 06, 2018, 01:50:21 PM »
Michael,
The new one piece Corian spark plugs look great.   :ThumbsUp: :ThumbsUp:
What type of coil are you now using? Do you know the output voltage? Some auto coils produce too high a voltage for our miniature spark plugs, which can make the plugs fail prematurely.
Please post the results of your tests and any developments
« Last Edit: December 06, 2018, 02:28:58 PM by Vixen »
Online steamer
« Reply #287 on: December 06, 2018, 05:21:30 PM »
I listened to a talk from Rollie Gaucher,  ...of Rollies Dads lathe alignment method fame.   He talked about making spark plugs using corian but its expensive    his comment was to bring a couple of models to the countertp shops, and theyll usually get so excited that theyll give you some off cuts for free.
Offline michelko
« Reply #288 on: December 07, 2018, 09:15:14 AM »
Mike,
at the end i was using an old Bosch Coil i had on the shelf. No idea what voltage it delivers.
In germany Corian is not realy expensive. On Ebay you can get rest pieces for a couple of euros.
Offline michelko
« Reply #289 on: December 10, 2018, 03:01:33 PM »
So i did some calculations and the actual CR should be 5,95:1.
What do you guys think, is this to high? Will the engine run with CR 5:1?. This is Maybe better for the Sparkplugs.
What CR do you guys run with your working engines.
« Last Edit: December 10, 2018, 05:12:51 PM by michelko »
Offline michelko
« Reply #290 on: December 10, 2018, 05:16:03 PM »
All parts ready machined, still have to cut the Center electrode to length and glue them together.
« Reply #291 on: December 10, 2018, 05:18:49 PM »
I have tended to design around 8-1, but this does not include the volume in the sparking plug or it's thread.
Offline michelko
« Reply #292 on: February 04, 2019, 08:54:45 AM »
Hi guys,
Little update on the Bugatti. I started to diassemble the engine.
I bought a cheap chinese pressure loosing tester to check for leaks.
Made an Adapter to fit the plug threads.
I found three leaking exhaust valves. Not realy bad but noticeable against the others.
All Inlet valves are leakfree :cheers:
The tool Shows realy low pressure loss on all cylinder (around 5 %).
But i think this tool is made for automotive engines with greater Dimensions so the numbers  it doesn´t mean anything.
I will then tear it apart and shorten the pistontops to reduce the cr.
Thinking so mutch about this problem i believe it is a combination between high compressionand high voltage from automotive coils.
So another step would be to reduce the high tension of the coils by shorten the dwelltime.
Online Vixen
« Reply #293 on: February 04, 2019, 09:37:38 AM »
Hello Michael,
I am sure your methodical approach with tests and measurements will help you get the Bugatti to run sweetly. :ThumbsUp: :ThumbsUp:
Do you have drawings of the cam profile and cam timing? It may be helpful if we can help you check the overlap and open durations.
Offline michelko
« Reply #294 on: September 27, 2020, 11:51:47 AM »
Hi Guys,
some time past since the last post about the bugatti.
I just found some motivation to complete it after the valve job.
While it was aoppart i redid some pieces.
The oilpump got new gears, the valve train aolso got three new gears to eliminate some backlash.
Also altered the exhaust a bit.
Next step will be cutting a gasket for the intake manifold with my cnc machine and a drag knife.
Here is a video while testing the oilpump, you can also notice the compression while cranking with the drill.
<a href="https://www.youtube.com/watch?v=a4nP-svwNLo" target="_blank">http://www.youtube.com/watch?v=a4nP-svwNLo</a>
Regards Michael
Offline nj111
« Reply #295 on: September 27, 2020, 02:33:48 PM »
Fabulous and sounds great spinning over!  Thank you for the update
Nick
Offline michelko
« Reply #296 on: September 27, 2020, 02:56:10 PM »
so here are some pictures from the intake and the new gasket. Made one spare while i was in there.
This is made from 0,5mm Gasketpaper, i also used this stuff as head gasket.
Regards Michael
Offline michelko
« Reply #297 on: September 29, 2020, 12:23:46 PM »
Hi guys,
it runs again, better than ever. The rework on the valves did the job i believe.
Not already tuneed in but runs nice. smoking from the last cylinders because of the oil bypass.
When that oilline is hokked up on its normal place i think it will stop smoking.
<a href="https://www.youtube.com/watch?v=v2F0rTHp8aM" target="_blank">http://www.youtube.com/watch?v=v2F0rTHp8aM</a>
Regards Michael
Online Vixen
« Reply #298 on: September 29, 2020, 12:34:44 PM »
Now that sounds sweet. The engine burbles away like only a straight eight can. Well done :ThumbsUp: :ThumbsUp:
Whats next, are you thinking about a simple blower like the original?
Stay safe
Offline michelko
« Reply #299 on: September 29, 2020, 01:03:45 PM »
i started to machine a dummy blower, just for appearance. Needs some more love and work.
Next step iwill be machining two cover plates on top of the crankcase.
Those will be made from plates 275x20x3mm. Still thinking about how to mount them on the mill.
Thought about gluing them on a larger plate, but how to loosen them after machining without bending??
Any sugestions?
Another project will be the Flywheel housing and the starter motor.
So plenty of worl to do before i can start another project (maybe a holt 75)
Regards Michael
