Here is Post #2 wich is the proof that the most difficult and time consuming part of an engine is the exhaust manifold.
Here is the story: Of course the manifold has to look as close as possible to the original. So the way to go is to cast this part. The outher shape is not a big deal but it is not possible to make a two pieced model of because there is no possible parting line on it. So i wanted ( and still wanting ) to use the lost wax method on this part and burn out the PLA - printing material out of the mould before casting.
While trying this i ran into a few problems which i was not able to solve until now :
1. The core ( which forms the gas passage ) can not be machined after the part has cast so the mould has to inklude a core.
This core is very thin ( 8mm ) and long because it goes trough the whole manifold .
2. The right material to make this core would be sodium silicate bonded sand but it is not possible to to use it on this shape.
The reason is i was not able to fill the sand in the plastic model and compress it because there are to much corners and the sand is not
liquid enough to squirt it in. So the only way is to make the core out of plaster of paris and use a injection sqirt to fill the model.
3. The plaster of paris made core is to fragile.
I tried to support the core with short pieces of steel wire to prevent it from falling to the bottom of the mould but i failed because of a
different reason.
4. The heat treatment of the mould to burn out the lost model is also a problem. While trying to cast the part as a one piced part the whole
mould would be a large block of plaster of paris. It lasts a very long time to bring the heat to the inside of the block to vaporize the
embedded plastics. This time is so long that the whole block will become cracks and beginns to become unusable.
The heat resistance of the plaster of paris investment material is not high enough. Maybe one mould out of ten would be usable.
Conclusion : As you can see in the pictures i tryed many times to make a one pieced casting of the manifold and every time i tried the reason for the failure was different. Yesterday was my last attempt and the problem was that there was still plastics left in the mould when i filled it with molten aluminium.
New plan :
I give up and will try something different. I will cast smaller sections of the manifold wich will include only one corner in the gas passage so i will we able to use sodium silicate sand for the core and maybe also for the outer investment material. Many of my problems are caused by the plaster of paris material so i have to ged rid of this material at least for the core section.
I will use brass to cast the sections to be able to hard solder them together when i have all of them. My first try will take place today.
Here a few pictures of my failed attempts. No comment.
