Valves are made and also the valve seat machining in the heads is finished.Valve seats are also made now and the usual valve grinding operation with final vacuum test.
Quote from: fumopuc on November 01, 2017, 07:13:06 PMValves are made and also the valve seat machining in the heads is finished.Valve seats are also made now and the usual valve grinding operation with final vacuum test. Nice work!I'm always interested to see how others do their valve assemblies.- what material are the valve seats made from?- did you lap the valves in a dedicated seating pot or the valves within their respective seats- how about your vacuum test, do you look for a long term hold or if it decays to ambient after X amount of time?- what kind of lapping compound?
