Author Topic: Zee's Shop Beginnings  (Read 76304 times)
Re: Zee's Shop Beginnings
« Reply #705 on: January 21, 2018, 09:00:05 PM »
Wahoo!!
 :whoohoo:
He's (almost all the way) back!
Have you decided what to start on? (stanley)
With all new tooling, something straightforward would make sense (not that that has ever stopped us) to begin with, to work out all the kinks and learn the new controls.
« Reply #706 on: January 21, 2018, 09:43:58 PM »
Not sure. I've got a couple of kits that I'm thinking about.
But that popcorn engine keeps calling me.
One of the kits is the#7 Twin. Probably that.
« Reply #707 on: January 26, 2018, 10:55:17 PM »
It's too early to start a build thread but I've immediately run into a question...
The attached picture is the base for the PMR Twin #7 model.
You see the four posts sticking up through which the crank goes.
How to drill/ream for the crank?
Standing it up in the mill and using a long bit seems a no go. Not enough head room.
Doing it with a short drill from both ends doesn't sound like a good idea. I doubt the holes will be true. Much like tunneling from two directions.
Another option is to clamp the base to the lathe carriage and use a long bit in the chuck.
(A nice feature of the carriage is two T-slots and it happens my clamping kit from my small rotary table fits!)
Thoughts?
For the lathe I'd have to be pretty careful to be in-line with the chuck and at the right height.
P.S. I've already flycut the bottom. More on that when I start a build thread.
Thanks.
« Last Edit: January 26, 2018, 11:43:26 PM by zeeprogrammer »
« Reply #708 on: January 26, 2018, 11:23:58 PM »
I'm not seeing the picture...?
« Reply #709 on: January 26, 2018, 11:43:43 PM »
Sorry about that. It's attached now. Thanks.
« Reply #710 on: January 27, 2018, 12:03:44 AM »
Could always mill off ghe posts in one go, close to the base, and make four bearing blocks that bolt on.
« Reply #711 on: January 27, 2018, 12:08:18 AM »
As for doing it in the mill, can you use a drill size for which you have a collet? Then ream behind the drilled holes. Just my 2 cents.
« Reply #712 on: January 27, 2018, 12:40:55 AM »
 :ShakeHead: That would destroy 'the look'.
Not sure. I do have a 3/16 collet for the first go. But would need to get a 15/64 to enlarge before reaming.
Then there's the reamer. Which looks like it could fit a 15/64 collet but I'm not sure.
The base would stand about 7". The drills and reamer would have to clear that and still get through all 4 posts. About 5" of travel.
Seems I would need 12" spindle to table. I have 11". Possible if I'm willing to move the table between operations.
I'll look into that more (mount the base in the mill) and see if my math is right.
Anyone have thoughts about using the lathe? Good or bad?
P.S. Bill...your 2 cents (as well as other forum members') are generally worth a fortune in my shop.
« Reply #713 on: January 27, 2018, 12:50:17 AM »
I assume the shaft size is 1/4".
« Reply #714 on: January 27, 2018, 12:55:56 AM »
Couple of times i put the 3 jaw chuck on the mill spindle, so I could choke up on the drill bit and reamer, gained some soace. Depends if the thread is same on your mill and lathe?
« Reply #715 on: January 27, 2018, 01:04:27 AM »
I do it often too Chris for drilling and reaming only. Really helps on Sherline/Taig sized machines.
« Reply #716 on: January 27, 2018, 01:08:45 AM »
@Bill...Yes. 1/4" shaft.
@Chris...I guess that works with a Sherline. I don't see a way to put a 3 jaw chuck on the mill...and it's very large. No thread on the mill. R8.
I'll mock it up this weekend and see what kind of space I really have.
I sure am interested in people's thoughts about using the lathe to do this though. The drawings state "To ensure the Cylinder is square with the Base, chuck on the cylinder so it can be bored and the base end faced in the same setup".
That 'in the same setup' seems to imply a lathe. No? But I actually don't know what that statement means.
« Reply #717 on: January 27, 2018, 01:17:26 AM »
And two cylinders right? Zee the lathe is fine as long as you can get the height right. Fortunately the cylinder bores and crankshaft hole(s) should be at the same height.
« Reply #718 on: January 27, 2018, 03:35:10 AM »
Right.
I'll give it a shot. What could go wrong?  ;D
« Reply #719 on: January 27, 2018, 07:37:23 AM »
Zee I often use the lathe for doing the bearing holes on the large hit & miss engines and it works well.  Determine what your exact ctr height above the cross slide is and then pack up the base to suit. You may find it easier to fix the casting to a plate so you can clock the edge of the plate for the bearing holes and then rotate 90degrees, clock again and do the cylinder mounting faces so all is true and at the same height
You could also do it in the mill if you don't have a specific collet then make a simple bush to take the drill bit and to fit a larger collet with a grub screw to clamp the drill bit. Alternatively 6.0mm is a good pilot for a 1/4" reamer and collets available. Would up through a few lengths of drill starting with a standard then long series and then extra long series if needed.
« Last Edit: January 27, 2018, 08:07:15 AM by Jasonb »
