Author Topic: Benson engine  (Read 40408 times)
Re: Benson engine
« Reply #240 on: November 16, 2017, 03:03:36 AM »
Kirk,
It's a good thing you locked the shop elves out cause they'd have a field day with those small parts. Looks great, runs great.
Re: Benson engine
« Reply #241 on: November 16, 2017, 09:48:53 PM »
All put back together.  I tested that it ran before adding the governor stuff, so once I get around to shortening a bunch of 0-80 screws I should be able to call this one done.
Not in a diorama, nor do the governor or pump actually work, but the end result is the "look" I was after.
This will be delicate to take to CF.
Re: Benson engine
« Reply #242 on: November 17, 2017, 12:01:09 AM »
Looks great!
For travelling, can the flywheel be removed to take off the weight of it from the rest?
Re: Benson engine
« Reply #243 on: November 17, 2017, 01:25:09 AM »
I can remove the flywheel and governor.  Probably need a box with foam padding for the rest.
Offline Flyboy Jim
  • Independence, Oregon
Re: Benson engine
« Reply #244 on: November 17, 2017, 04:29:09 AM »
That is a very nice looking engine. I like the balance of brass to other materials.  :ThumbsUp:
Sherline 4400 Lathe
Sherline 5400 Mill
