I don't talk about my studs anymore, I embarrassed some of the members with my tales of what I do with them and they have rarely been seen since
I learned the term astragal only from Jason where he mentioned it in JL's build. Today's work was to make the steam chest, and since JL already made this it's not a mystery part. After sizing the stock (I happened to have some 3/8x3/4" brass bar, the first ops on the CNC mill were just to drill the mounting holes (2-56 clearance) and mill the interior pocket. A 1/8 endmill would have been quicker, but none of mine had flute length < 1/4". So I found a 7/64 with over 1/2" flute length, but which I could feed at only 1.5 IPM. That pocket took nearly 30 minutes to mill, but I had a book to pass the time. On a manual mill I'd have chain drilled out the center first.Then stood it up in the vise to profile the elliptical spigot and drill the necessary hole. Mounting screws are 1-78.This is certainly the smallest steam chest of any of my previous engines. An interesting observation is that Solidworks allows me to draw the spigot as an ellipse and when saving as DXF converts it to a polyline with 96 segments. I am wondering where in SW configuration is the setting for the tolerance that controls the segment generation.The problem with closeup photos is that you can see all the places I need to clean up.
@JL - I graduated with a mechanical engineering degree but worked as a software developer my entire career. All the mechanics has left me other than some concepts. But I can look up things and understand them (sometimes).
