The CylinderI know it's been ages since I've checked in, but I have indeed been plugging away at this engine when I have a little free time. I managed to finish the cylinder, which for my previous engines is where I always started. I really enjoyed working with brass for some of the cross slide parts, so I pulled out the wallet and ponied up some cash so I could machine the cylinder from brass as well. In hindsight, I think it was well worth the investment.
I dialed in a 1.5 inch long piece of 1.5 diameter brass (turned down from 1.625) and drilled/reamed a 0.375 inch hole down the middle
Rather than boring out the cylinder right away, I thought it might be easier to work on the rotary table if I made it match one of the centering plugs I have. I had to make a little spacer disk to pull the cylinder away from the RT table. Here I have the RT in its vertical setup so I can create steam passages.
This is the first time I've used my RT this way, and I learned real quick that a 6 inch RT is huge for my mill. The little spacer helped, but for these cuts the mill head needs to get down in there. I found the solution by facing the RT away from me, as you'll see in upcoming photos. This was a pain for seeing what I was doing, but it did work.
I did a little measuring and marking on the bench, and then dialed it in on the mill as you can see here. I was triple checking things so I wouldn't waste a nice hunk of brass. Here you can maybe guess I'll be making three cuts. The outer lines represent the steam inlet passages, and the middle line is the exhaust passage which wraps down the side of the cylinder. The cylinder isn't yet finished to length so you can see a mark near the RT reminding me to finish it to length somewhere along the way.
Here's my first cut which I did in a few passes with a 1/8 inch end mill. This is the exhaust passage that goes from 30 degrees on the back side to 75 degrees down onto the front side of the cylinder (relative to the top scribed line). The left side of the cylinder in this photo is the back of the cylinder. The rocking valve assembly will sit on top, and an exhaust port piece will be attached on the side over this passage. The parts will be soldered.
Perhaps this orientation on the other side of the RT makes more sense. The front side of the cylinder is toward the RT. You can see the exhaust passage is done, and I've just finished running through the back steam inlet passage. I took all these cuts in a few passes. Note that while the exhaust passage was cut via rotation of the RT, these steam inlet passages are cut straight across.
And there's the front inlet passage in the next photo...
Now the RT is switched to horizontal and I drilled/tapped the five mounting holes on the back side of the cylinder. The print called these out as #4-40 threads, but I realized that the hole size specified for the cross slide mount was for #3. Rather than drill the cross slide mount holes bigger, I made these mounting holes #3-48. I'm thinking the smaller bolts will make the engine look bigger
Next I drilled steam inlet passages that extended down to the first steam inlet passage I machined a while back. These are along the top edge of the cylinder which is at the left. Two pairs of holes form the passages, and dang they are close to the edge! The hole between these two pairs of passages is the top threaded mounting hole from the previous picture.
Next was the job of machining out passages into the cylinder bore. Of course I haven't yet bored the cylinder, so these just extended "enough" toward the center. I went 0.200 which was an easy four cranks of the dials (I don't have DROs). After this photo, I machined out the second pocket identical to the first.
Then I actually remembered to machine the cylinder to length before drilling/threading the six bolt hole circle on the front side of the cylinder. I made these #3-48 threads to match the other side.
Then the steam inlet pockets were created on this side in the same manner as the other side.
And finally, back to the lathe where I clocked it into the 4-jaw, drilled, and bored it to a 1 inch bore.
And here's my shiny new cylinder! I love brass.
And the family shot so far. It doesn't really assemble quite like this as there are front and back cylinder heads...the back one sneaking between the cylinder and cross head assembly, of course. But I couldn't resist putting it together with a single bolt like that.
Perhaps that was too many photos for most of you, but I had to make it look like there was lots to do to make the cylinder
. And for me, that was a lot of steps!
Next time will probably be the front/rear heads for the cylinder. Thanks for checking in!
Todd
