Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 176699 times)
Offline Firebird
  • East Midlands UK
« Reply #1200 on: June 24, 2020, 09:15:35 PM »
Hi
Got the hydrostatic lubricator finished and fitted
<a href="https://www.youtube.com/watch?v=003UYDozl1g" target="_blank">http://www.youtube.com/watch?v=003UYDozl1g</a>
Rich
« Reply #1201 on: June 24, 2020, 10:33:47 PM »
The hydrolubic staticator looks the business! Great job Rich.
Offline scc
  • Lancashire, UK
« Reply #1202 on: June 25, 2020, 11:21:24 AM »
I totaly agree :ThumbsUp:         Terry
Offline Firebird
  • East Midlands UK
« Reply #1203 on: June 25, 2020, 08:55:59 PM »
Hi
Thanks cnr6400 and Terry  :ThumbsUp:
Today I took the loco outside and prepared it for firing up on steam. Set it up on the rolling road.
Fill the boiler. Fill the side tanks. Fill the hydrostatic lubricator. Fill the drip feed lubricator. Oil round the axle boxes and motion.
Light a fire.
<a href="https://www.youtube.com/watch?v=igTvGWc5Goc" target="_blank">http://www.youtube.com/watch?v=igTvGWc5Goc</a>
And in reverse
<a href="https://www.youtube.com/watch?v=8KA4P_EKJZc" target="_blank">http://www.youtube.com/watch?v=8KA4P_EKJZc</a>
Rich
« Reply #1204 on: June 25, 2020, 10:27:35 PM »
Poetry in motion!!!   :whoohoo:
Offline Johnmcc69
  • Erie Pa., USA
« Reply #1205 on: June 26, 2020, 12:16:46 AM »
 :ThumbsUp:  :praise2:
 Awesome! You gotta be "Chuffed"!
 Fantastic build!
Offline michaelr
« Reply #1206 on: June 26, 2020, 09:07:01 AM »
Rich, Your Conway is running great a credit to your perseverance with those little problems that you had along the way.
Michaelr
« Reply #1207 on: June 26, 2020, 11:21:00 AM »
Congratulations Rich  :cheers:  you have a very fine runner now  :praise2:  and I'll bet that you wished you could take it to the track right now ....
Offline scc
  • Lancashire, UK
« Reply #1208 on: June 26, 2020, 12:08:52 PM »
Excellent, very enjoyable build and a great end product :ThumbsUp: :ThumbsUp:    Love to see things running on steam and am looking forward to" running on track video" :popcorn:           Terry
Offline Firebird
  • East Midlands UK
« Reply #1209 on: June 27, 2020, 10:06:03 AM »
Hi
Thanks Chris, John, Michael, Per and Terry  :ThumbsUp:
Yes it was a good day to see it running on steam.  ;D
The lubricator seemed to work well. At the end of the running period I opened the drain valve and out came clear water followed by hot oil
<a href="https://www.youtube.com/watch?v=CL7Tic4Lzcs" target="_blank">http://www.youtube.com/watch?v=CL7Tic4Lzcs</a>
I have got a steam leak in the pipe though which should be an easy fix
<a href="https://www.youtube.com/watch?v=6rxFsiAQwmE" target="_blank">http://www.youtube.com/watch?v=6rxFsiAQwmE</a>
Rich
Offline Firebird
  • East Midlands UK
« Reply #1210 on: July 02, 2020, 11:14:12 AM »
Hi
Well Conway is nearing completion. There are a few little jobs that need tinkering with but for the most part its complete.
The next big job is to get it down to our club and have the boiler inspector do the steam test and then hopefully take it for a run around the track.
Unfortunately with circumstances being what they are that may be some time away, possibly towards the end of the year.
So today I have decided to have a clear out and make way for a new project.
I have a bench full of bits for Conway that are now surplus to requirements. Some are duplicated parts, some are parts that have been upgraded or modified etc. The following video is a brief description
<a href="https://www.youtube.com/watch?v=E4QuR_U2UVs" target="_blank">http://www.youtube.com/watch?v=E4QuR_U2UVs</a>
Its a shame to just dump it all so I would like to offer it all free to anybody that fancies building this loco. It would of course have to be collection only due to the size and weight or arrange your own courier
Rich
« Last Edit: July 04, 2020, 09:50:16 AM by Firebird »
« Reply #1211 on: July 03, 2020, 07:21:43 AM »
Splendid  :praise2:  :praise2:  :wine1:
I hope you don't have to wait too long for your club to reopen.
Offline Firebird
  • East Midlands UK
« Reply #1212 on: September 11, 2020, 01:44:29 PM »
Hello fellow lock downers and lock downesses I trust you are all coping with the extra shed time :Lol:
Well our club is still shut so I can't take Conway for its steam test.
I have repaired a few niggling leaks etc
So today I had her outside for a steam up, just to keep things turning over.
I have a question for you my learned friends
The loco runs on steam ok as the above video shows but to coin a phrase it literally runs out of steam. After 30 seconds or so the fire has almost burnt out, the pressure drops to around 25psi. I have to feed it with wood to get the fire going again and once up to pressure it will run again for 25/30 seconds or so and then run out of steam again. I can't feed the fire fast enough or keep it hot enough to keep it going.
Any ideas  :headscratch:
Rich
Offline michaelr
« Reply #1213 on: September 11, 2020, 02:47:02 PM »
From what you say about the fire and lack of steam, I would look at the blast nozzle size if the blast doesn't keep the fire going your engine is not going to make steam, a small diameter nozzle bore will pull the fire, a large diameter bore will not pull the fire, but you have to hit a bore size that will pull the fire and also be manageable it's trial and error until you get the right size to suit your engine.
Have you tried running with the blower open, if that works then it's the blast nozzle at fault.
Mike.
Offline Firebird
  • East Midlands UK
« Reply #1214 on: September 11, 2020, 05:12:49 PM »
Hi Mike
Perhaps I should have written a little more information.  :facepalm:
The blast nozzle works fine. Once I have the boiler up to 30psi I can remove the electric blower from the chimney and use the loco's own steam blower. The pressure rises quite quickly to 80psi, its running pressure, and will maintain that pressure. Put it in forward gear and open the regulator the loco runs but its then that it runs out of steam and has all but eaten the fire in 30 seconds
Rich
