Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 178823 times)
Offline Firebird
  • East Midlands UK
« Reply #900 on: July 21, 2019, 07:27:50 AM »
Hi
Thanks Roger and Mike  :ThumbsUp:
Sorry for the slow reply, I have just returned from the family holiday
Rich
Offline Firebird
  • East Midlands UK
« Reply #901 on: July 21, 2019, 07:10:55 PM »
Hi
Just before we went away on holiday I started to assemble the regulator but came across a problem.  :thinking:
The central spindle has to have a spring on it to keep the disc pressed against the regulator body face. The drawing clearly shows a nice gap around the spindle
But in practice there is no such gap
I have checked and double checked the drawing and it simply doesn't work, perhaps another Martin Evans error
To overcome the problem I have made another disc but moved the tapped holes out by 1/32". It meant that I had to make another lower part with its tapped holes moved out by 1/32"
Now I have room for the spring
Rich
Offline mike mott
  • Alberta Canada
« Reply #902 on: July 21, 2019, 08:31:13 PM »
It is disconcerting to find these sorts of errors. It makes for a lot of wasted effort.
Offline Firebird
  • East Midlands UK
« Reply #903 on: July 21, 2019, 08:37:07 PM »
Hi Mike
That is quite true.
I spent the best part of a very valuable day in the workshop trying to overcome the problem and there is still a little more work to do.
Rich
Offline Firebird
  • East Midlands UK
« Reply #904 on: July 28, 2019, 06:06:27 PM »
Hi
Confident that I have the regulator sorted its time to start assembling things. The regulator body is fixed to the boiler by 2 stainless steel screws. Plenty of thread seal was applied
Followed by the tube that screws into the regulator through the bush in the smoke box, using the tool to screw it in. Thtread seal used again
Followed by the wet head bush which screws into the bush in the smokebox and at the same time screws onto the tube from the regulator, using the tool to screw it in. thread seal used
Then the wet head and super heater
Remember I said I was confident about the regulator. I spoke too soon  :facepalm2: :facepalm:
The regulator inner dome won't fit over the regulator
Strip it all down again. Make a split collet to hold the central bolt and shorten it
Now it fits. Make a gasket and bolt it on
The backhead has its cover fitted. Then the regulator bush, handle, water guage, blower valve, firehole door etc
The rear section of boiler cladding with a couple of brass bands
The cover on the front of the firebox and the cover over the firebox
The front section of boiler cladding with 2 more brass bands
The boiler clack valves fitted,one each side
2 blowdown valves fitted. One each side
The boiler is pushed firmly into the smoke box. A couple of screws, one each side is all that is needed
The following 7 photos are more trial assembly work
Rich
Offline mike mott
  • Alberta Canada
« Reply #905 on: July 28, 2019, 06:12:36 PM »
Wow that is looking really spiffy.
Offline Johnmcc69
  • Erie Pa., USA
« Reply #906 on: July 28, 2019, 08:51:02 PM »
"WOW" is right...that is BEAUTIFUL!
« Reply #907 on: July 28, 2019, 11:09:13 PM »
Looking great Rich!
« Reply #908 on: July 29, 2019, 02:25:39 AM »
Couldn't agree more!  That is really looking good!  :ThumbsUp: :popcorn:
Offline Firebird
  • East Midlands UK
« Reply #909 on: July 29, 2019, 08:05:11 PM »
Hi
Thanks Mike, John, cnr6400, and Kim  :ThumbsUp:
Although I have many of the parts already made they all seem to need fettling to achieve a good fit so its taking time.
Rich
« Reply #910 on: July 29, 2019, 08:17:22 PM »
That's a lot of bits to assemble  ::) Looks excellent  :praise2:  :praise2:
Offline Firebird
  • East Midlands UK
« Reply #911 on: August 18, 2019, 03:12:56 PM »
Hi
Thanks Roger :ThumbsUp:
I haven't posted much lately but I have been busy with lots of fiddly fettling and modifying etc.
Another bit of tool making which you might be interested in. The blow down valves need a square key to open and close them.
Here's my method of machining a square hole.
Start with a bit of round stainless steel and drill to a depth of about 1/2"
Move over to the mill and machine a slot
Machine a bit of stainless to the same width as the slot
Silver solder in place making sure the square hole is true
Machine away the excess. Cross drill for a T bar handle
Which leaves me with a key with a square hole
Rich
« Reply #912 on: August 18, 2019, 03:21:22 PM »
Nicely made Rich. Now you can blow the boiler down AND wind the clock!  :Lol:
Offline Firebird
  • East Midlands UK
« Reply #913 on: August 18, 2019, 03:56:09 PM »
Hi
Thanks cnr6400 :ThumbsUp:
I have moved the lubricator from the front of the running board to underneath the running board on the rear left hand side. In its previous position the linkage was too long and exposed and had already been knocked a few times.
Its mounted on a stainless steel plate. You can also see the much shorter linkage
The bottom connection fitted and a start made on running the 1/8" pipe
Rich
Offline Firebird
  • East Midlands UK
« Reply #914 on: August 18, 2019, 04:10:44 PM »
Hi
The oil check valve fitted
Rich
