Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 176887 times)
Offline Steve17
« Reply #705 on: January 13, 2019, 07:09:12 PM »
Hi Rich,
Personally I go for about 69 for running in and then up from there as it is not so thin that it just runs out. A little off but there was a prolific builder near hear used to run in with brasso first then flush through with thin oil and then thicker. He never used to strip down to clear out the brasso just flush out.
Steve.
Offline Firebird
  • East Midlands UK
« Reply #706 on: January 17, 2019, 07:33:54 PM »
Hi
Thanks Steve, I have found some 69 on ebay  :ThumbsUp:
A bit of progress today. I think I have the valves set  :cartwheel:
Many thanks to Nick for his setting instructions  :ThumbsUp: :cheers:
The new eccentrics with their external grub screws make the job a whole lot easier
<a href="https://www.youtube.com/watch?v=-5nFaqv3mwg" target="_blank">http://www.youtube.com/watch?v=-5nFaqv3mwg</a>
I have some more photos to upload they will follow later this weekend
Rich
« Reply #707 on: January 17, 2019, 07:53:50 PM »
Sweet!
Time to sit back and admire!
« Reply #708 on: January 17, 2019, 09:40:28 PM »
It must have felt great when it came back together and worked as shown in the video, after the previous mishap  :cheers:
« Reply #709 on: January 18, 2019, 05:45:51 AM »
That's some pretty slick movement there, Rich!  :ThumbsUp:
« Reply #710 on: January 18, 2019, 11:08:38 AM »
Hello Rich,
Awesome work :NotWorthy:
Offline Firebird
  • East Midlands UK
« Reply #711 on: January 20, 2019, 09:36:47 AM »
Hi
Thanks Chris, Admiral, Kim and Thomas  :ThumbsUp:
Got the steam T made up. Its as per the plans the photos should provide enough info
One thing to note though. The oil check valve that will screw into the front is tapped 5/16" x 40. They are cheap enough to just buy one and save me the trouble of making it but I cannot find a supplier that has one in 5/16 x 40 they all seem to be 1/4 x 40. Had I checked that first I would have tapped the hole 1/4 x 40
Rich
Offline Steve17
« Reply #712 on: January 20, 2019, 10:54:40 AM »
Looking good. I understand where you are coming from with the drilled and tapped holes for fittings. Hope you can bend the copper tube ok with the end fitting on.
Steve.
Offline Firebird
  • East Midlands UK
« Reply #713 on: January 20, 2019, 01:53:47 PM »
Hi Steve
In the text he says to use copper, brass or gun metal
Which must be bent after fitting.
I don't fancy trying to bend gun metal or brass so copper it is
Rich
« Reply #714 on: January 20, 2019, 02:14:06 PM »
Just catching back up with your build Rich. Some amazing progress and beautiful results!!
Offline Steve17
« Reply #715 on: January 20, 2019, 02:37:36 PM »
Fair point Rich, it just caught my eye the bend in the copper tube shown on the smokebox drawing.
Steve.
« Reply #716 on: January 20, 2019, 03:02:19 PM »
The Steam Tee looks great Rich!
I found a couple of 5/16"-40 taps on Amazon:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=tap+5%2F16-40
Several of them are Prime and you could have it in 2 days :)
Good luck!
Offline Firebird
  • East Midlands UK
« Reply #717 on: January 20, 2019, 03:44:15 PM »
Hi
Kim its not the taps, I have already tapped the hole. It seems oil check valves are not commercially available in 5/16 x 40
Rich
« Reply #718 on: January 20, 2019, 04:47:26 PM »
Ah, I get it.  I misunderstood the issue.  Maybe you could make a check valve? :)
Offline g0rph
« Reply #719 on: January 23, 2019, 11:21:11 AM »
Hi Rich,
If you really want to use a commercial 1/4 x 40 oil check valve you could just reverse that steam-T (leaving your plug in place) and just drill/tap the other side?
The steam-T is symmetrical (leastways it is on my Conway!) so that should work?
While on that part, my steam pipe screws into the top of the T.   If you solder it in it (like Martins drawing) you need a larger hole in the smokebox floor, to clear the 1/2 inch threaded end, and that is rather more difficult to seal!
The screwed-in approach also makes fitting the smokebox a little easier if the pipe is bent.  Mine is straight but leans forward slightly - there is just enough clearance to the blast nozzle.
Regards, Richard.
« Last Edit: January 23, 2019, 12:19:48 PM by g0rph »
