Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 176042 times)
Offline Firebird
  • East Midlands UK
« Reply #675 on: December 17, 2018, 07:10:02 PM »
Hi
Thanks Chris and Nick  :ThumbsUp:
I don't know when I will get back onto it  :'(
I'm working this week then there is something called Christmas that will get in the way  ::)
I need to have a good few days in the shop on maintenance, drill and tool sharpening etc. I am also midway through fitting a DRO onto the old Myford and some new drawers are long overdue. I think all this will be my goal for the Christmas holidays.
Anyway I would like to wish one and all a very merry Christmas and a happy new year
 :whoohoo: :cartwheel: :cheers: :DrinkPint:
Rich
« Reply #676 on: December 17, 2018, 07:35:41 PM »
Same holiday wishes to you Rich. Enjoy your time off in the workshop. I plan to be in my shop a good bit of the holiday time too. :whoohoo:
Offline Firebird
  • East Midlands UK
« Reply #677 on: December 29, 2018, 06:04:35 PM »
Hi
Thanks cnr6400 :ThumbsUp:
Well the tool sharpening got done, the new drawers have been built and fitted and the DRO has been fitted to the Myford.
Do you recall a while back I picked up a part built 0 6 0 Simplex. Well on ebay over the holiday someone advertised a boiler for a Simplex which I duly won :)
So yesterday Julian and I set off for Cheltenham, about a 2 hour drive to pick it up. As far as I can see it has been well made and pretty much as per the plans. All copper and silver soldered. I have had my endescope camera inside and all looks well so happy days. I will take it to our club to let the boiler inspector give it the once over in the new year.
Today was back on conway but not such a happy tale  :(
I am still struggling with the valve/eccentric setting. I seem to be able to get 3 of them set up(it doesn't matter which 3) but things get decidely stiff and when the 4th is tightened up it is almost impossible to turn.  :facepalm:
So I have stripped the whole lot out again and thrown the towel in for today :disappointed:
Rich
PS
Happy new year everyone  :cheers: :DrinkPint: :wine1:
« Reply #678 on: December 29, 2018, 07:49:41 PM »
Sorry to hear your troubles Rich. :(
I'm sure you'll get it sorted, but it can be frustrating trying to work through it.
Best of luck.  I'm here rooting for you! :)
And glad to hear your other purchase is looking good! :)
Offline Barneydog
  • Just outside Leicester, United KIngdom
« Reply #679 on: December 29, 2018, 11:06:41 PM »
Dont worry i will help you......beer and whisky sorts most things!
Julian
Offline Firebird
  • East Midlands UK
« Reply #680 on: December 29, 2018, 11:14:35 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp: :ThumbsUp: :ThumbsUp:
Having the whiskey now
 :cartwheel: :cartwheel:
Offline Firebird
  • East Midlands UK
« Reply #681 on: December 30, 2018, 03:46:38 PM »
Hi
I have found a problem. The eccentrics are not sitting  true on the axle.
You can see from this photo how much they are out  :facepalm:
After some deliberation the only thing to do is strip the axle out again
This is going to be a challenge  :thinking: :headscratch:
Firstly drill the pin out of the crank.
Then hopefully with a bit of heat press the crank and the wheel off.
Looking back at my method of making the eccentrics, (go back to page 21) I can see that the offset hole for the axle should have been bored in the lathe and not drilled and reamed in the mill
Rich
« Reply #682 on: December 30, 2018, 05:12:23 PM »
Ouch! Sorry to hear about that one, hope the rest of the assembly can be re-used!
« Reply #683 on: December 30, 2018, 06:10:16 PM »
Yeow! That's a bummer  :(
Once you get it apart, what's the plan? Plug the eccentric and re-drill?  Or make a new one?
Offline Firebird
  • East Midlands UK
« Reply #684 on: January 01, 2019, 12:12:17 PM »
Hi
Thanks Chris and Kim :ThumbsUp:
Happy new year everyone :drinking-41:
I have a few ideas that I am playing around with.
A new set of eccentrics will be needed but this time bore them on the lathe Richard  :slap:
I am wondering if I can make all 4 with the external grub screw with new eccentric rods with a greater off set to suit  :thinking:
Rich
Offline Firebird
  • East Midlands UK
« Reply #685 on: January 03, 2019, 08:18:56 PM »
Hi
The first job was to remove the pin from the crank which stubbornly refused to move. I drilled out some of the fat side of the pin
Turned up a punch from some silver steel and then knocked it out
Set up in the press with pressure on the end of the axle and heat applied to the wheel
Then pressure applied again and heat applied to the crank
Going completely off topic for a moment here's the boiler I picked up last week for the Simplex I have
Ok back on topic.
Turn a piece of steel to the flange diameter
Then move to the mill and centre under the quill
Move the table over  1/4" and centre drill
Back in the lathe and centre on the off set point
Firstly drill
Then bore out to size
<a href="https://www.youtube.com/watch?v=aDRpEih1eHQ" target="_blank">http://www.youtube.com/watch?v=aDRpEih1eHQ</a>
Carefully with the last few cuts until the test bar fits
<a href="https://www.youtube.com/watch?v=95t4P7UQd8U" target="_blank">http://www.youtube.com/watch?v=95t4P7UQd8U</a>
Then test with the axle
Re centre in the lathe
Turn to size and part off
2 down 2 to go
Rich
« Reply #686 on: January 03, 2019, 08:27:46 PM »
Nice, glad it came apart cleanly, back moving forward again.
« Reply #687 on: January 03, 2019, 10:06:11 PM »
That must be a relief to get them apart in such a way that you can reuse most of the assembly  :cheers:
Nice looking boiler - hope it will be useful without too much trouble  ;)
Offline Firebird
  • East Midlands UK
« Reply #688 on: January 05, 2019, 07:35:31 PM »
Hi
Thanks Chris. Yes it came apart quite easily , better than I expected
Thanks Admiral. It looks like all the parts are re usable
The boiler looks to have been really well made, I'm happy with it.
All 4 new eccentrics have been made and are a much better fit on the axle and running true. The 2 outer eccentrics, the ones next to the wheels have had their flanges increased in width form 1/16" to just over 1/8". Just enough room for me to get a 1/8" grub screw in. My plan is to use the small 1/8" external grub screws to set the valves. They will be good enough to just nip the eccentrics in place. I can then remove the caps to tighten the main grub screw. The eccentric rod will need to have a slight kink made to take up the extra 1/16" or so.
Thats the plan anyway  ::)
I have taken a couple of steps back while its stripped down again to get everything turning as freely as possible.
The wheel has been put back on the axle but not fixed permanently. The axle box fitted, and the crank fitted with just a pin.
I have a couple of lengths of aluminium track so that has been fixed down to a length of MDF
Big lads train set  :jumpingsmileys: :jumpingsmileys:
<a href="https://www.youtube.com/watch?v=DmiXHujNFAM" target="_blank">http://www.youtube.com/watch?v=DmiXHujNFAM</a>
Rich
« Reply #689 on: January 06, 2019, 12:58:13 AM »
That is mighty cool Rich!  :ThumbsUp: :popcorn:
Thanks for the video :)
