Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 178187 times)
Offline Firebird
  • East Midlands UK
« Reply #450 on: May 20, 2018, 09:33:55 AM »
Hi
Thanks Chris, Cletus, Kim and Nick  :ThumbsUp:
Craig, have you got a photo or sketch of that set up
Rich
« Reply #451 on: May 20, 2018, 09:38:02 AM »
Good work on the boiler  :praise2:  :praise2: I like your solution to the reversing lever handle and the support stand  :ThumbsUp:  :ThumbsUp:  :wine1:
Offline Firebird
  • East Midlands UK
« Reply #452 on: May 20, 2018, 06:33:24 PM »
Hi
Thanks Roger  :ThumbsUp:
Back to the reversing lever.
The latch starts life as a bit of 3/8" x 1/8" steel bar. I won't detail every little operation. I hope the following series of photos will suffice but any questions just ask
Rich
Offline Firebird
  • East Midlands UK
« Reply #453 on: May 20, 2018, 06:50:40 PM »
Hi
The latch block starts life as a bit of 5/16" square steel.
Likewise I'll show a series of photos
A pin of stainless steel with an M3 thread
Then all in the zinc plating kit
Finally a bit of video
<a href="https://www.youtube.com/watch?v=OR2MbXmGRt8" target="_blank">http://www.youtube.com/watch?v=OR2MbXmGRt8</a>
Rich
« Reply #454 on: May 20, 2018, 07:34:49 PM »
Very nice, Rich! I love seeing tiny parts.
On your zinc plating set-up: What are you using for electrolyte?
Offline Firebird
  • East Midlands UK
« Reply #455 on: May 20, 2018, 07:41:31 PM »
Hi
Thanks Pete  :ThumbsUp:
Re the zinc plating I did a topic here
http://www.modelenginemaker.com/index.php/topic,6305.msg128542.html#msg128542
Rich
« Reply #456 on: May 25, 2018, 08:13:10 PM »
Hi
Rich
Better late than never I suspect.
Offline Firebird
  • East Midlands UK
« Reply #457 on: May 28, 2018, 09:22:33 PM »
Hi
Thanks for that Craig  :ThumbsUp:
I need to finish the smoke box before I can mount the boiler in the frames.
The smoke box door is available as a casting for about £18.00 but I am going to make one from steel.
Starting with a bit of 1/2" thick steel, mark out, drill and cut roughly to size.
Turn a mandrel and mount the blank
Turn the outer edge to size then with the top slide turned to its maximum profile as much as possible
Machine the back
So far so good
Machine a bit of 1" x 1/4" steel to make the hinge
Drill 6 holes in the hinge and tap 2.5mm. Drill 6 corresponding holes in the door
The original brass hinge bracket I silver soldered into the smoke box front was heated up to melt the silver solder and removed. Anew more sturdier bracket was machined from brass and drilled.
A new pin made from stainless steel
The parts given a zinc plating
The brass bracket silver soldered into the smoke box front and a trial fit
Looks ok
Rich
« Last Edit: May 28, 2018, 09:26:23 PM by Firebird »
« Reply #458 on: May 28, 2018, 09:38:02 PM »
Looking excellent.
I need to learn more about zinc plating. How long did it take to plate?
Offline Firebird
  • East Midlands UK
« Reply #459 on: May 28, 2018, 10:25:51 PM »
Hi
Thanks Carl  :ThumbsUp:
Around 10 minutes for smaller parts I left the door in for about 1/2 an hour
Rich
« Reply #460 on: May 28, 2018, 11:32:58 PM »
Hi
Rich
Is the plating just for corrosion protection, or will that be the final appearance of the parts? Are you plating the brass as well?
« Reply #461 on: May 29, 2018, 03:32:10 AM »
Nice post on the smoke box door. I'm with you - making it rather than buying the casting just seems fun to me.  Not knocking the castings - to each his or her own.  But I like making it myself!  And you did a bang up job here Rich.
Offline Firebird
  • East Midlands UK
« Reply #462 on: May 29, 2018, 06:08:53 PM »
Hi
Thanks Chris and Kim  :ThumbsUp:
The zinc plating is a bit of both, corrosion protection and appearance. Some parts like the reversing lever and stand will be left with just the plated finish while other parts will be painted.
Rich
Offline Firebird
  • East Midlands UK
« Reply #463 on: May 31, 2018, 09:40:40 PM »
Hi
A bit more work on the smoke box today.  Fairly straight forward but a few things worth mentioning
The dart starts life as a bit of 3/8" stainless steel turned down to 3/16". It then needs a 1/8" square machining on the end. To do this I used my latest acquasition a square collet block
Purchased from arceurotrade (usual disclaimer)
http://www.arceurotrade.co.uk/Catalogue/Collets/ER-Collet-Fixtures/Stevensons-ER40-Collet-Blocks
I went for the ER40 which will take a collet for 1". I also purchased a straight adapter
http://www.arceurotrade.co.uk/Catalogue/Adaptors-Sleeves/Morse-Taper-Straight-Sockets---For-Tang-Type-Tooling
Which means I can use all my MT2 collets
After machining the square its back in the lathe to turn down and thread M3
Reverse and hold in a 3/16" collet and turn the taper
Then back in the collet block to machine the 2 flats
The 2 handles are straight forward one being tapped M3 but the other needs a 1/8" square hole.
To do this I machined a 1/8" square onto some 3/8" silver steel, filed some notches on the corners with a triangular file and then heated to red and quenched to harden it
In the press to broach the square hole
After a clean up a trial fit. The cross bar needs no explanation
Rich
« Last Edit: May 31, 2018, 10:17:22 PM by Firebird »
« Reply #464 on: May 31, 2018, 10:05:52 PM »
Nice!  :ThumbsUp: Loved the detailed post.
