Hi
Some more work on the regulator
Using a T slot cutter to machine the body
The regulator is held into the boiler by 2 screws through the top of the boiler barrel. Which means the tapped holes have to be cut on the same radius as the boiler. It took a bit of working out
A long series drill just gets the job done
Followed by a tap
The bottom of the body where the 2 3/16 holes were drilled has to be blanked off. Drill and tap a couple of 3mm holes
Make a brass cover
Drill and tap 5/16 x 40 tpi for the steam pipe
The links that attach to the pivot must be free to rotate so I am trying stainless steel bushes on 3mm stainless steel cap heads
The pivot needs a 1/8" square hole in its centre. A piece of silver steel in the rotary table has a 1/8" square machined on the end
Heat treat to harden just the end. Then in the press the square cutter is pushed through a previously drilled 1/8" hole
It worked well
Cut off and fettle a bit
Getting there
Rich
