Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 178527 times)
Offline Firebird
  • East Midlands UK
« Reply #180 on: August 22, 2017, 08:13:17 PM »
Thats a good question Willbert
I have absolutely no idea  :shrug: :thinking: :headscratch: :noidea: :ShakeHead:
Rich
« Reply #181 on: August 22, 2017, 10:49:57 PM »
A lot depends on the steel hammer. A heavy one will move the metal more, work hardening it faster, though the distance moved is similar. Ghe danger with a steel hammer is denting the metal. A wide slightly convex hammer is used for things like bowl raising, takes a bit more skill than forming over a lip with a plastic or hide mallet. For making the endcaps, the plastic or hide mallet is a much better way to go.
Offline Firebird
  • East Midlands UK
« Reply #182 on: August 23, 2017, 08:52:08 PM »
Hi
A printed template is stuck inside the smokebox tubeplate and all the positions centre punched. 4 of the holes are drilled 4mm
Screwed to a piece of scrap wood
By moving the screws about all the holes can be centre drilled
The larger holes, one for a bush and one for a super heater tube are firstly drilled out with a step drill
the super heater 1" hole needs to be slightly undersize for now so a guage is used
Finally the firetube holes are reamed 1/2"
Rich
Offline scc
  • Lancashire, UK
« Reply #183 on: August 23, 2017, 09:11:01 PM »
Rich, Thank you for  troubling to detail your build as you do. It makes inspiring reading. I'm following and enjoying :cheers:
Regards            Terry
« Reply #184 on: August 23, 2017, 10:38:19 PM »
Following along, very interesting!
Offline Firebird
  • East Midlands UK
« Reply #185 on: August 29, 2017, 07:19:12 PM »
Hi
Thanks Terry and Crueby
Quite early on in the text it says make the large bush that the regulator goe's in and silver solder into a large hole in the top of the boiler. There is no mention of drilling and tapping you sort of have to work that out from the description of the cover that fits over the regulator, the cover isn't mentioned until much later on  :thinking: Anyway 8 tapped holes are required, the plans specify 6BA but I have gone with 3mm.
The bush set up in the rotary table, drilled and tapped
Now onto the large hole, 1 3/4" in the top of the boiler. I knocked up a jig to hold the boiler from scrap wood, and bolted it down in the mill. A couple pull ties help to keep it it in position
A step drill removed most of the waste
Followed by the boring head. I had to add a couple of angle plates to the set up to stop the boiler moving sidewards
carefully machine until the bush just fits
I'm not going to solder the bush in just yet. The regulator looks like a tricky job on its own, I'll look into that first
Rich
« Reply #186 on: August 29, 2017, 07:35:03 PM »
Rich, its best not to fully tap any bushes as the heat of soldering can damage the threads. Best to just start a taper tap by a couple of turns so it locates easily after soldering to finish the job. Apart from that looking good.
Offline Firebird
  • East Midlands UK
« Reply #187 on: August 31, 2017, 12:41:30 PM »
Hi
Thanks for the tip Jason  :ThumbsUp:
The regulator body is a gunmetal casting, cost me £17 so I don't want to mess it up.
A small piece of oak
5 minutes on the band saw and I have something similar
Which means I have something I can play about with and shows that if I do mess up the casting I could hack one out of brass
Rich
Offline Firebird
  • East Midlands UK
« Reply #188 on: August 31, 2017, 06:59:10 PM »
Hi
Ok then my learned friends we have a problem  :help:
The regulator. I don't know why but I was worried about this little so and so.
In the mill and fly cut the port face and the lower mounting. A good finish was achieved
Drill and tap the port face 5BA. Drill the lower face 1/8"
Centre drill the position of the two ports
Fly cut the bottom face
Two 3/16" holes have to be drilled very close together to a depth of 3 1/2" !!!!!
First centre drill. Then drill down with a standard length drill. Change to a long series drill, the depth marked with a bit of masking tape. The right hand side drilled perfectly. The left hand side went ok to about half way down then the drill wandered off and ended up drilling into the first hole  :censored: :'( :cussing:
I cross drilled the two port holes and they both joined up with the long hole. Blowing through there is a clear passage.
Will that allow enough steam through.
Rich
« Reply #189 on: August 31, 2017, 09:02:31 PM »
What does that regulator do? Is it a type of safety valve?
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #190 on: August 31, 2017, 10:43:00 PM »
Is that not what a throttle is called on a locomotive?
Tom
« Reply #191 on: August 31, 2017, 10:45:47 PM »
Hi Richie,
 That's a bugger! Sure others will jump in but I would think that as you have a reduced bore size by basically 1/2 that you will be short of steam! At 3 1/2 deep I don't think you would find an end mill that would reach anywhere near total depth. Sounds like there may of been a hard spot that kick off the drill. As a possible fix how about flipping the regulator over & drill, milling down from the top on the effectd side & hopefully managing to connect  to the "short" hole, tap & plug the entry point.
All the above assumes that you want to keep the current regulator & dont want to get another casting, or make one from solid.
Looking forward to other suggestions!
Chris Tom yes throttle equals regulator in loco speak!
Richie,
 Just had another thought, flip the regulator so the port face is down, & mill the back of the regulator out, so that you open up the drilled bores to a rectangular opening full width of the 2 holes, will give you a bigger opening for the steam. When done silver solder in a cover plate.......sounds easy......
« Last Edit: August 31, 2017, 10:49:59 PM by Steamer5 »
Offline Firebird
  • East Midlands UK
« Reply #192 on: September 01, 2017, 06:12:58 PM »
Hi
Thanks Kerrin, I sort of went along the lines you suggested  :cheers:
Out of trouble I think
Firstly I opened up the end with a 3/16 cutter as I deep as possible
Then milled a slot in the side
A piece of 3/16 brass rod in the good hole to act as a guide
And finally the long drill. I decided to do this by hand sooner than in the mill, has a better feel
Now all I have to do is make up a piece to fit in the slot.
Rich
PS
Will brass be ok to silver solder in the slot or do I need to use gun metal
« Reply #193 on: September 01, 2017, 08:00:23 PM »
PS
Brass takes silver solder very well.
Offline Firebird
  • East Midlands UK
« Reply #194 on: September 02, 2017, 11:40:27 PM »
Hi
Heres the piece that fits in the slot, machined from brass
Its in the pickle now
Moving onto the disc, chuck a piece of stainless steel centre drill and face. I use a home made cutter with round tool steel for facing, I get a very fine finish
Move over to the rotary table, drilltwo 3/16 holes and two tapping size holes for 3mm
Back in the lathe and part off
The bolt, stainless steel, called for some fine turning and milling
Rich
