Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 177513 times)
Offline JULIUS
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #90 on: March 05, 2017, 12:50:17 AM »
Rich
I see on two pictures that you use some of my drawings. Are they any help? You know that my drawings are for a 5" engine!
Julius
Offline Firebird
  • East Midlands UK
« Reply #91 on: March 05, 2017, 08:20:47 AM »
Hi Julius
Yes I know they are for 5" but they have been very useful as general arrangement drawings, helps me to visualise where things go :ThumbsUp:
Rich
Offline Firebird
  • East Midlands UK
« Reply #92 on: March 05, 2017, 04:16:30 PM »
Hi
A pair of axles
I'm quite pleased with them, accurate to within a thou. I should have fitted DRO's to the lathe long ago :facepalm:
One of the wheel blanks has been turned to 1/2" thick, bored and reamed 9/16" and the recess machined. 3 more to go then turn a mandrel to mount them on and turn the tread and flange
I will need a short length of track. 6 pieces of alluminium offcuts have 12mm slots machined 3 1/2" apart
2 lengths of 12mm square steel 3 foot long. I know I know imperial and metric in the same sentence :naughty:
I just have to screw them down to a bit of MDF now
Rich
Offline Firebird
  • East Midlands UK
« Reply #93 on: March 09, 2017, 08:00:24 PM »
Hi
Drilled and tapped 5mm and held together with 5mm countersunk socket head screws
Screwed down to a bit of MDF
Rich
Offline Firebird
  • East Midlands UK
« Reply #94 on: March 12, 2017, 04:57:06 PM »
Hi
The 4 wheel blanks have been turned to 1/2" in width, bored and reamed. 2 of them I have machined the recess. For some reason I found this hard work, changing from left hand tools to right hand then back again so I am going to have a go at the last 2 in the mill on the rotary table.
I have turned a mandrel, drilled and tapped 8mm to hold the wheels to turn the tread and flange.
Rich
Offline Firebird
  • East Midlands UK
« Reply #95 on: March 19, 2017, 05:11:01 PM »
Hi
I found a round cutting tool which is ideal to turn the tread leaving a nice radius into the flange
To round off the flange I have made a form tool. A piece of silver steel is held in the vise at an angle and has a 3/32 hole (the width of the flange) drilled through. Holding the silver steel at an angle while drilling gives a relief angle to the cutting edge.
Then machine away the end to half way across the hole. Heat treat to harden, I didn't bother to temper it. Clean up with a diamond file
A disc of alluminium was used as a test piece
The cutter worked really well
Turning the steel wheel
Then slipped them onto the axle
I couldn't resist dropping the frame on to see how things look
Rich
« Reply #96 on: March 19, 2017, 06:19:53 PM »
Nice!
Using the form tool helps ensure the flanges on all the wheels look the same. I'll have to remember that.
Online Roger B
« Reply #97 on: March 19, 2017, 07:47:36 PM »
Looking good  :ThumbsUp:  :ThumbsUp:  :wine1:
« Reply #98 on: March 19, 2017, 08:35:21 PM »
I'm not sure that you belong here if you could  :D - nice build  :ThumbsUp:
Offline Firebird
  • East Midlands UK
« Reply #99 on: March 25, 2017, 11:21:26 PM »
Hi
Thanks Carl Roger and Admiral
All 4 wheels now have the turning finished. A slight lack of attention on one wheel  :old: saw it machined differently to the other 3 so I have re machined them so that they are all equal. Not quite to plans but near enough and they are all the same.
I have cut 2 pieces of 1/4" thick steel plate and held them on the wheel mandrel
Then turned them to the diameter of the the recess in the wheels
The balance weights will be cut from these
Rich
« Reply #100 on: March 26, 2017, 02:10:19 AM »
Sorry about the re-do on the wheels Rich, but they sure are looking good now!
Offline Firebird
  • East Midlands UK
« Reply #101 on: March 26, 2017, 08:02:01 PM »
Hi
Thanks Kim
I made a boss from alluminium and sunk it into a scrap of wood
Cut off in the bandsaw
In the mill to machine to 5/8"
A nice fit
Rich
« Reply #102 on: March 26, 2017, 10:35:37 PM »
That's pretty slick Rich.  Are you going to solder them in place?
Looks like you might have been able to get 3 weights out of one circle.  That wouldn't have helped you much when you need 4 weights, but if you needed 5 or 6 then you could save a disk!
Offline Firebird
  • East Midlands UK
« Reply #103 on: March 27, 2017, 08:02:41 PM »
Hi Kim
I think I will fix them in with 1 countersunk screw and a bit of loctite
Rich
« Reply #104 on: March 27, 2017, 11:01:24 PM »
I can't wait to see more. Making up the wheels is very interesting.  :ThumbsUp:
