Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 175259 times)
Offline Firebird
  • East Midlands UK
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #825 on: April 27, 2019, 08:37:53 PM »
Hi
Heres the insulation as purchased, its 2mm thick
I am going to use 2 layers, ie 4mm thick. For the boiler barrel I needed to cut a piece from each sheet. Then wrapped with adhesive heat proof aluminium tape.
The boiler barrel on this loco is 14 inches long. I have borrowed my mate Julians rolls which are 12 inch so I am going to wrap the boiler barrel in 2 sections, the first being 10 inches.
I first made a template from cardboard (sorry no photos) then used that to mark out some brass sheet
A hole saw to drill the large hole for the dome
Then in the rolls
A trial fit
Like wise the front section was made
 4 lengths of Brass banding cut to length. 8 pieces of 3/8 x 3/8 brass angle cut and drilled. 4 pieces drilled 2.5mm and 4 pieces drilled and tapped M2.5. Its useful to rig up a length stop in the vise when making multiple parts. the brass angles are silver soldered to the ends of the banding
After a quick polish
The forward/reverse lever reac rod has been modified. It slopes up at an angle (see earlier picture) which is ok if a saddle tank is fitted but I am going with side tanks so it gets in the way. A piece of brass is drilled and tapped and fitted to the reach rod to drop it down by 4cms.
While I was at it I have replaced the spacer with a bit of steel angle which will give support to the running board
You can see the reach rod now sits almost parallel
Rich
« Reply #826 on: April 27, 2019, 09:06:04 PM »
Looking good Rich!  :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
« Reply #827 on: April 28, 2019, 05:25:08 AM »
That's a lot of progress, Rich!
Pass the popcorn Cnr ;D :popcorn:
Offline Steamer5
  • The "Naki" New Zealand
« Reply #828 on: April 28, 2019, 08:03:47 AM »
Hi Richie,
 A lot of work & looking good!
You won’t to be careful posting all those pictures of brass! Don will getting twitches to polish something!
A quick question, what is & were did you get your insulation from please?
Cheers Kerrin
Offline Firebird
  • East Midlands UK
« Reply #829 on: April 28, 2019, 08:50:16 AM »
Hi
Thanks cnr6400, Kerrin and Kim  :ThumbsUp:
I pick up the insulation at model engineering shows, its not something you see regularly.
A search on google tells me its Kayowool Ceramic Fibre Insulation material
https://www.camdenmin.co.uk/collections/kayowool-ceramic-fibre-insulation-material
Rich
Offline Steamer5
« Reply #830 on: April 28, 2019, 09:20:42 AM »
Hi Richie,
 Thanks for the info!
Cheers Kerrin
Offline J.L.
« Reply #831 on: April 29, 2019, 10:22:55 PM »
Hi Rich,
I am in awe of this thread and the work involved in bringing you to this point. I appreiate the amount of time required to construct each part you have fashioned by hand.
You are a master at this craft of model engineering. Here I am assembling parts that have been die cast and enjoying every minute of learning about the engineering involved.
You on the other hand are making them!
Outstanding work.
Offline Firebird
  • East Midlands UK
« Reply #832 on: May 02, 2019, 07:46:08 PM »
Hi
Thanks John, praise indeed.
I'm following along in the background on your build, impressive model :popcorn:
Time to get the running boards made and fitted. They are around 26" long and 2" wide so a decent sized bit of sheet is needed. Looking through my stock the only thing I could find was a bit of stainless steel sheet which was big enough to yield the 2 running boards. The down side though is stainless steel is difficult to work.
The stainless steel sheet is 1.5mm thick, so to cut it down to size I clamped it between 2 pieces of angle iron in the vise and cut it with a thin steel cutting blade in my angle grinder
At 26" long it is beyond the travel of my milling machine so I had to stop half way and shift it along. Keeping the cutter speed quite low the edge machined ok. I used a 12mm carbide cutter.
The left hand running board needs to have a bit machined out to clear the forward/reverse lever. I changed to a 6mm carbide cutter for this
Pieces of 1/2" x 1/2" brass angle to support the running board. I have used the holes that were intended for the spring hangers
A piece of 1/4" x 1/4" brass angle to finish the edge. Drilled and tapped M2.5. On final assembly I will change the socket head screws for button head screws
Made a start on the right hand running board
Rich
« Reply #833 on: May 03, 2019, 05:54:23 AM »
Wow, the running boards add a lot to the look!
And it's amazing how much work those seemingly simple items actually take!  But it's sure looking good  :ThumbsUp: :popcorn:
Offline Firebird
  • East Midlands UK
« Reply #834 on: May 05, 2019, 10:24:28 AM »
Hi
Thanks Kim  :ThumbsUp:
I have started to mock up the cab and right hand side tank.
For the cab I have printed out actual size from the plans (had to do it on 2 sheets of paper and join down the middle)
Then spray glue to a bit of scrap hardboard
Likewise the 2 cab sides have been printed out and glued to card board
The cutout for the boiler needs to be enlarged. As shown its only 4" the size of the boiler tube and doesn't allow for the cladding
A cardboard side tank
Rich
Offline Firebird
  • East Midlands UK
« Reply #835 on: May 05, 2019, 01:49:18 PM »
Hi
I have made a start on the right hand side tank. Normally brass sheet would be used but I don't have any, but what I have got is a sheet of copper, 18gauge (.050"). Its of no use for boiler making, too thin so side tanks it is.
I used a nibbler to cut out a rough piece then trimmed with tin snips
Finished by filing clamped between 2 pieces of angle iron
Then in the folder
A piece of scrap copper has a hole drilled with a hole saw to check what size it turns out to be
Some brass tube turned to size
Drill the hole in the tank
Make 2 blind bushes
Drill 2 holes in the bottom plate
Silver solder the bushes in
Silver solder the bottom plate into the tank
2 holes will be drilled in the running board and the tank bolted in place
Rich
« Reply #836 on: May 05, 2019, 02:21:00 PM »
Looks great Rich! Tanks for posting! (sorry for bad pun)  :ThumbsUp: :ThumbsUp: :ThumbsUp: :popcorn: :popcorn: :popcorn:
« Reply #837 on: May 05, 2019, 03:25:50 PM »
Very nice!  copper seems expensive to use when not required, but I guess if you already have it, it's cheaper than something else, eh?
So, is there only a tank on one side?  Does that make the engine run lopsided?  :-\
Offline Firebird
  • East Midlands UK
« Reply #838 on: May 05, 2019, 04:15:54 PM »
Hi
Thanks cnr6400, nice pun  :ThumbsUp:
Hi Kim. The copper sheet I acquired/gained/found years ago. It is a nice sheet but has little use in our hobby, too thin so side tanks it is. Yes there are 2 tanks, one each side. I started with the right side because its a straight forward tank. The left side will be more difficult/challenging. Although its the same size it has to have a cut out on the inside to give clearance to the reach rod
Rich
« Reply #839 on: May 05, 2019, 09:35:30 PM »
Considering how much work you have put into this model already - it's almost funny how the last few items added makes look so much more like a locomotive  :noidea:
Great work Rich  :cheers:       :popcorn:
