Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 112426 times)
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #570 on: September 13, 2018, 09:17:35 PM »
More very impressive work...
 :popcorn: :popcorn: :popcorn:
Offline Firebird
  • East Midlands UK
« Reply #571 on: September 14, 2018, 09:17:47 AM »
Hi
Thanks Chris  :ThumbsUp:
Watching you as well  :popcorn: :popcorn: :popcorn:
The front and rear beams are made of 1/8" steel. I have read in a couple of other loco builds that 1/8" is not really strong/rigid enough for a loco of this size and power especially on the rear drag beam. I toyed with the idea of making another from 1/8" steel to double the thickness but searching through my stock I found a bit of 5mm thick steel so made a new one. It took only 15 minutes to make using the old one as a template
The brass angles that support the cab floor and rear end of the running boards are cut, drilled and tapped M3.
Once fitted and bolted in the frame is noticably stiffer
Rich
Offline Firebird
  • East Midlands UK
« Reply #572 on: September 15, 2018, 12:27:46 PM »
Hi
PS
As the front and rear beams are identical I have decided to fit the now spare rear beam to the front, doubling the thickness there.
cheers
Rich
Offline Kim
« Reply #573 on: September 15, 2018, 05:34:54 PM »
Enjoying your build, Rich.  Love the red bumpers!  And I'll bet the additional thickness on the front and rear beams will add a lot of rigidity to the frame.
I always have to wait till the weekends to read your thread. Well, its not weekends so much as wait till I'm reading from home!  Your pictures won't show up for me at work.  For some reason, the place you host your photos is blocked by the firewall at work.  But I see them fine at home.  :-\
Great progress Rich,  :ThumbsUp:
Offline Firebird
  • East Midlands UK
« Reply #574 on: September 15, 2018, 06:53:00 PM »
Hi
Thanks Kim  :ThumbsUp:
The front beams doubled up
Rich
Offline Firebird
  • East Midlands UK
« Reply #575 on: September 15, 2018, 07:01:55 PM »
Hi
After a rub down with wet and dry the frames get a couple of coats of etching primer
Followed by 3 coats of smooth Hammerite
Ladies and gentlemen we have ourselves a loco frame
 :whoohoo:
Rich
« Reply #576 on: September 15, 2018, 07:48:27 PM »
Look good Rich  :ThumbsUp:
Will follow along to see you complete this build  :popcorn:  :cheers:
Offline Firebird
  • East Midlands UK
« Reply #577 on: September 15, 2018, 08:30:52 PM »
Hi
Thanks Per  :ThumbsUp:
While waiting for the preverbial paint to dry I busied myself with a little work on the axle boxes.
First job was to make 4 plates from stainless steel that fit across the spring studs
Followed by drilling the top half firstly 3/16" then 1mm to form oil cups
And finally with a 5/16" end mill form a recess in the bottom half for a felt pad
Rich
Offline Kim
« Reply #578 on: September 15, 2018, 11:19:41 PM »
The paint makes it really start to look like a locomotive, doesn't it?
I'm getting ready for that step myself and I'm worrying about it. I'll say you have done a fine job of it!
Offline Firebird
  • East Midlands UK
« Reply #579 on: September 16, 2018, 08:59:26 AM »
Hi
I am a fan of Hammerite, both the hammer finish and the smooth. It needs a good week or so to really harden off but once hardened it gives a really hard wearing finish. The aerosols are good for getting a decent finish.
Rich
« Reply #580 on: September 16, 2018, 10:31:30 AM »
Hi Rich,
Frame now in color looks really good.
Have a great day,
Offline Firebird
  • East Midlands UK
« Reply #581 on: September 20, 2018, 08:55:44 PM »
Hi
Thanks Thomas  :ThumbsUp:
I have to make a start on assembling the loco now. Some parts can't be fitted until other parts are fitted which means fitting some other parts  :thinking:
Spray painted the wheels red
Fitted all the horn blocks
Then I spent quite some time fettling each axle box to get a nice sliding fit
Fitted the axle pump and the valve rod guides
Fitted the front lower stretcher/safety angle and round stretcher
I need to fit the cylinders before I can fit the motion but firstly I need to make and fit some cylinder covers. Because I have cut the cylinders from the solid and not used castings I have some angled corners to worry about. Some stainless steel sheet is cut to size and folded to fit the cylinders
Rich
« Reply #582 on: September 20, 2018, 10:07:39 PM »
Very nice!
Offline Kim
« Reply #583 on: September 21, 2018, 05:20:27 AM »
Nice progress, Rich.  Like the video of the axle boxes! I assume there will be springs involved there?
Another newbie question; what's the point of the cylinder cover?  If its for insulation, it doesn't seem like a thin piece of sheet metal is going to help hold much heat in.  Is it for looks?
Thanks,
Offline Firebird
  • East Midlands UK
« Reply #584 on: September 21, 2018, 08:30:29 AM »
Hi
Kim. You will have to go back quite a few pages to find the section on the axle boxes and horn plates but briefly its this. The original drawings for Conway show the loco with leaf springs. Talking to the guys at our club as to where to source materials, spring steel and tufnol, the general concensus was convert to coil springs if you can. They are much easier to set up than leaf springs and easier to maintain. Fit dummy leaf springs if necessary, they are available as bronze castings, many locos do this. The horn blocks I did purchase as a bronze casting but it was of very poor quality and in places slightly undersize before machining. With hindsight I should have sent the casting back but hey ho. Some say using steel horns and cast iron axle boxes is a better option anyway.
The cylinders can be purchased as castings but at a whopping £336.00 I opted to have a go at machining them from the solid. Cast cylinders do have some detail but are a bit rough so most locos fit cylinder covers to tidy things up. I did think that my cylinders looked ok with the nice smooth sides and would be ok just painted but in the end decided to make some nice shiny covers. They are held on with just 4 bolts which screw into tapped holes in the cylinders so I decided to drill and tap the cylinders now before they are fitted. I have to fit the cylinders in order to line up the motion. Once fitted I don't want to take them off again.
Hope that helps
Rich
