Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 179041 times)
Offline Firebird
  • East Midlands UK
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #420 on: April 14, 2018, 10:15:53 PM »
Hi
Thanks Carl  :ThumbsUp:
I forgot to show the table locking device
Looking around my stock of phospher bronze I found what I think is a brake shoe. I must have picked it up at a steam fair for a few pence but it would yield the die blocks.
Screw it to the table
Move the mill table over the required amount and machine the inside face
There is enough material for three die blocks. Drilla nd ream the 5/32" holes
Move the mill table again and machine the outer face
Cut out the three die blocks and finish to size
Rich
« Reply #421 on: April 14, 2018, 11:01:57 PM »
That worked great! Gotta love ingenuity!   :ThumbsUp:
Offline Firebird
  • East Midlands UK
« Reply #422 on: April 19, 2018, 08:28:55 PM »
Hi
Thanks Chris  :ThumbsUp:
The expansion links are machined in a similar way. Print out and stick a template to a piece of 1/4"  X  1 1/4" gauge plate. Drill 3 holes. 2 are part of the link the 3rd is in the waste area
Cut the first link off the bar and use as a drill guide to drill the second piece. Screw them to the rotary table as a pair. Machine the slot first then the outer profile.
After machining
Testing with a die block. The die block hasn't been finished to size yet
Rich
Offline Firebird
  • East Midlands UK
« Reply #423 on: April 26, 2018, 08:11:06 PM »
Hi
The brackets are machined from 1/2" square BMS
Profiling
Not exactly the shape on the plans but they can't be seen and this isn't a show standard engine
The studs I made as one shaft, pushed through with a bit of loctite in the bracket then the centre part hacksawed out. The links are drilled and tapped M3 and the brackets drilled 3mm
Rich
Offline Firebird
  • East Midlands UK
« Reply #424 on: April 26, 2018, 09:31:38 PM »
Hi
Moving onto the crossheads.
Once again gun metal castings are available but at nearly £40.00 its worth making them. I am using cast iron because I have a bit. Cast iron and the steel of the slide bars are a good combination of materials.
Firts job is to machine the block of cast iron to size
Then each side has a 5/16" wide slot machined
Testing with a bit of 5/16" square. Aiming to get a good fit
My usual method of printing out exact size and gluing to the work piece
In the mill and machine away some of the waste. I have enhanced some of the print out with a marker pen
Rich
« Reply #425 on: April 27, 2018, 01:01:34 AM »
I have missed a few posts Rich, but the progress is amazing and as has been said, the photos are excellent as usual.
Offline Firebird
  • East Midlands UK
« Reply #426 on: April 29, 2018, 08:32:11 PM »
Hi
thanks Bill  :ThumbsUp:
The two cross heads are seperated and some more material machined away
Then the slot
Drill and ream
Then open out one side and countersink
Rich
Offline Firebird
  • East Midlands UK
« Reply #427 on: April 29, 2018, 08:45:55 PM »
Hi
A bit of experimental work. The gudgeon pin looks like a right tricky little so and so.
Start with some 1/4" silver steel and drill
Machine the end
Part off
Turn round and countersink
These 2 are M5 and 2 BA. The M 5 might be too big on the head. I am going to try M4 next to see which is the best fit.
Rich
« Reply #428 on: April 29, 2018, 08:55:29 PM »
Nicely done.
I know it would be tricky for me. What made it tricky for you?
Offline Firebird
  • East Midlands UK
« Reply #429 on: April 30, 2018, 08:55:00 PM »
Hi
Carl, I just don't get on too well with really small parts. I doubt I could get a good enough finish on the shank part of the gudgeon pin. Using a bit of silver steel that is already finished to a high degree seemed a better option.
I'm not going to do any more to the crossheads for now. Some more fettling will be required to get the con rods to fit nicely so without further ado lets get on with the con rods.
I bought the con rods as laser cut parts. At £8.46 each its not bad. To make them myself I would still have to buy the material.
Here they are
A quick measure up first. there is not a lot to spare. The big end needing only 6 thou off each side. It was then I noticed they are not straight.
I am assuming the heat generated by the laser cutting must have warped them. So a bit of gentle persuasion in the press  was called for
Set up in the mill using the DRO to accurately drill the holes
Drill the holes
A  bit of scrap something or other to make a jig
2 short pins are drilled 6mm so that the studs and T bolts fit through. Extra clamps that can be moved around as nec
Machine the big end
Change the clamps around, machine the con rod then the small end
Machine the big ends as a pair. drill for the oil hole
Some more filing will be required to clean them up. I have drilled the small end 3/8" because I have some ball bearings that size. I might still go with the bronze bushes for now. If they wear quickly I will change them for bearings
Rich
Offline Firebird
  • East Midlands UK
« Reply #430 on: May 03, 2018, 09:14:37 PM »
Hi
The con rods are given a polish up
The coupling links are similar to the con rods but slightly shortly
Measuring them I found they are .230 thick which is under the 1/4" on the plans. Thats not even 6mm. Its not a problem as the bushes are the critical width. I have decided not to machine the width but leave them flat.
After machining and polishing which is similar to the con rods I gave them all a dip in the zinc plating kit
After plating
Bushes for the con rods are straight forward turning jobs
In the text it says not to make and fit the coupling rod bushes until after the wheels have been quartered so I'll leave them for now.
The intermediate valve rod cross heads are machined as per the plans
Rich
Offline Firebird
  • East Midlands UK
« Reply #431 on: May 06, 2018, 06:58:10 PM »
Hi
Some more bits
The weigh shaft bearings, a simple turning and drilling job
The plans show them as lozenge shaped, I assume castings are available.
They fit here
They can't be seen so I am not going to spend time machining them to shape as per the plans.
The valve spindle couplings are also fairly straight forward and are machined as per the plans except I am tapping one side M5
Start by preparing a couple of bits of steel to size
Drill and tap
Then machine out the corner and profile
Rich
Offline Firebird
  • East Midlands UK
« Reply #432 on: May 12, 2018, 07:51:05 PM »
Hi
The reversing lever and stand has some small fiddly bits so I'll show a bit of the detail
Starting with a couple of bits of 1/8" steel plate drilled as per the plans
A couple of washers on each bolt as spacers
My home made rotary table being centred and squared under the quill
Move the table over 3 1/4" and position and mount the stand
Machine the outer then the inner radius
Machine the outer faces to size
The stand fits here
The reversing lever starts as a piece of 3/8"  X  1/8" steel flat bar. I used the DRO to accurately drill the holes
Roughly shape the handle leaving oversize
You can see on the plans that the handle is 3/16" at the top but the steel is only 1/8" thick.
Heat up then hammer until its 3/16" thick
Square up in the mill with extra support from an angle plate and centre drill
In the 4 jaw and centre with a Dti
Turn the top slide a few degrees and carefully turn using a tail stock centre to support
Turn a couple of spacers 1/8" thick
The trigger starts as a bit of steel in the mill and carefully shape
Drill 2 holes
Cut off and file to shape
A 1/8" slot is milled across the bottom, sorry no photo I forgot  :old:
Thats it so far
Rich
« Last Edit: May 12, 2018, 08:13:57 PM by Firebird »
« Reply #433 on: May 12, 2018, 09:10:13 PM »
Nice job on that handle. It wouldn't have occurred to me (lack of experience) to heat and hammer to make it thicker. Nice.  :ThumbsUp:
Offline Firebird
  • East Midlands UK
« Reply #434 on: May 13, 2018, 02:11:46 PM »
Hi
Some good news today. I took the boiler to our club and had the initial hydraulic test done. This is carried out at twice working pressure 160psi. I 'm happy to say it passed  :whoohoo: :wine1: :cheers: :DrinkPint:
A major milestone reached and passed  :cartwheel:
Rich
