Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 177965 times)
Offline Stuart
  • Tilchestune UK
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #210 on: September 22, 2017, 07:53:11 PM »
Rich
 to fit longitudinal stays you need some me constant pitch taps and dies
you use say a 32tpi set then you thread the stay say 1/4 32 tpi now your boiler bush must be the same tpi but bigger
next you make up a nipple thread the OD to 32 tpi to fit the bush and then tap the id to 1/4 32tpi
by using the same thread pitch it will screw on to the stay and into the bush
this is normally used to fit a hollow stay for a blower but can be used for solid stays
glad to see some one else from the EM on here
google my place name and you will see same neck of the woods
« Reply #211 on: September 22, 2017, 08:00:39 PM »
Stay nipples are quite simple, something like this just enlarged proportionally to suite your thread sizes
Offline Firebird
  • East Midlands UK
« Reply #212 on: September 23, 2017, 04:06:34 PM »
Hi
Thanks Jason and Stuart.  :ThumbsUp:
The nipples are not drilled right through? They seal onto the threaded bush with a copper washer?
Rich
« Reply #213 on: September 23, 2017, 04:13:39 PM »
Drilled and tapped right through, soldered to seal.
Offline Firebird
  • East Midlands UK
« Reply #214 on: September 24, 2017, 10:19:48 AM »
Hi
Thanks Jason.
Is there a reason for making the stays this way? :thinking:
Would it not be easier to just silver solder the stays directly into the smoke box tube plate and back head, or do the threaded nipples add mechanical strength?
I assume that since the nipples are silver soldered to the boiler and become part of it they must be made from phosphor bronze or gun metal not brass. There is no mention of them on the plans.
Rich
Offline Firebird
  • East Midlands UK
« Reply #215 on: September 24, 2017, 11:25:48 AM »
Hi
Some more boiler work.
An hour or so in the woodworking department to make a couple of formers
Annealing the copper plate for the outer wrapper
Bending the outer wrapper around the former. This has a clamp fitted to hold the plate in position
The inner wrapper being shaped
make 2 bushes for the top of the outer wrapper, one for the safety valve and here one for the manifold
Drill 2 holes in the outer wrapper with a step drill
The 15 fire tubes are cut to length and have there ends turned square. The super heater tube had to be held using a fixed steady
Rich
Offline Firebird
  • East Midlands UK
« Reply #216 on: September 24, 2017, 04:57:18 PM »
Hi
One more photo
Rich
« Reply #217 on: September 24, 2017, 06:24:41 PM »
Really coming along great!!
Offline Barneydog
  • Just outside Leicester, United KIngdom
« Reply #218 on: September 24, 2017, 08:51:09 PM »
Looking good.
Saw it all this morning.
You catching up with my Simplex. We will have to "launch" them at the club together!!
Julian
Offline NickG
« Reply #219 on: September 24, 2017, 09:32:48 PM »
Nice work on the boiler Rich.
Offline Barneydog
« Reply #220 on: September 24, 2017, 09:33:01 PM »
Hi,
Afetr we discussed the bushes for the blower stay here's the ones I made for my Simplex. They have the bush and the nipple. The nipples have a connection for the pipes that will fit onto them. I will seal them in with loctite thread seal or ptfe.
Figured the big pics.
Julian
« Last Edit: September 24, 2017, 09:57:11 PM by Barneydog »
Offline Firebird
  • East Midlands UK
« Reply #221 on: September 28, 2017, 09:14:13 PM »
Hi
Thanks Crueby, Nick and Julian
A bit more boiler work, the crown stays.
Make a cardboard template and mark out for 4 pieces on 1/16" copper
After shaping
The 4 pieces are bent to make feet and a central piece made also from 1/16" copper. drilled with 1/16" copper rivets pushed in but not riveted yet
All the pieces are in the pickle now.
While they are in the pickle I have made a start on the regulator inner dome. I have a piece of thick walled brass tube that needs to be machined to size. I made a mandrel to machine the outside
Turn the outside to size
In the 3 jaw with fixed steady support to bore the inside
Rich
« Reply #222 on: September 28, 2017, 09:37:54 PM »
Interesting how the crown stays are done, do they touch the inside of the outer shell too?
Offline Firebird
  • East Midlands UK
« Reply #223 on: September 29, 2017, 09:01:10 PM »
Hi Crueby
No they don't attach to the outer wrapper they just reienforce the firebox wrapper
Rich
Offline Firebird
  • East Midlands UK
« Reply #224 on: September 30, 2017, 05:08:37 PM »
Hi
All the tubes have a few thou turned off for 3/16"
I used my parting off blade as a length guage
Hand wind some silver solder round a bit of 1/2" bar
Cut into rings
File some nicks into each of the tube holes in the firebox tube plate so that the silver solder will flow through
Drop all the tubes into the well fluxed tube plate and add the silver solder rings
Fit the smoke box tube plate to the front end to help keep them in line.
Ready to be silver soldered
After silver soldering
After a while in the pickle
I think I've got it  :cartwheel: :cheers:
A mock up to check on progress
Rich
