Author Topic: CONWAY 0-4-0 3 1/2" GAUGE LOCO  (Read 179603 times)
Offline mike mott
  • Alberta Canada
Re: CONWAY 0-4-0 3 1/2" GAUGE LOCO
« Reply #1020 on: December 13, 2019, 02:47:28 PM »
That all looks like a great help, Rich being able to shift heavy models and tools without hurting ourselves is something we don't think about much when we are in our 20's and 30's but add 40 or 50 years and it is a different matter.
« Reply #1021 on: December 13, 2019, 02:48:31 PM »
Great crane - could have used one of those a few times here!
Offline Firebird
  • East Midlands UK
« Reply #1022 on: December 13, 2019, 06:56:05 PM »
Hi
Thanks cnr6400, Mike and Chris  :ThumbsUp:
There are still 2 more bits of kit needed  ::)
A set up of possibly chain to attach the hoist hook to the loco
A short length of track fitted into the back of the car
Rich
Offline Firebird
  • East Midlands UK
« Reply #1023 on: December 14, 2019, 12:58:05 PM »
Hi
I had a spell on the loco today, refitting the boiler etc
Got the pressure test kit connected up and did a test.
Leaking out of the snifting valve  :facepalm:
<a href="https://www.youtube.com/watch?v=svMxiRsdjq4" target="_blank">http://www.youtube.com/watch?v=svMxiRsdjq4</a>
As far as I can see the only way it can leak from the snifting valve is if water is getting by the regulator  :facepalm2:
Rich
« Reply #1024 on: December 14, 2019, 03:37:09 PM »
The engine  is looking good  :praise2:  :praise2: I hope the leak can be easily fixed  ::)  ::)
Offline Firebird
  • East Midlands UK
« Reply #1025 on: December 14, 2019, 04:43:20 PM »
Hi
Thanks Roger  :ThumbsUp:
Before I strip the boiler out again I need to know exactly where the leak is.
I am going to remove the dome and take out the regulator and fit a blanking plug then refit the dome and pressure test again.
If it still leaks then it has to be the internal pipe.
Rich
Offline Firebird
  • East Midlands UK
« Reply #1026 on: December 14, 2019, 07:48:37 PM »
Hi
I have removed the dome and stripped out the regulator
Made a blanking plug
And fitted it
Unfortunately I have created another problem  :facepalm:
When I tried to pressure test it the dome bush leaked badly. 2 of the M3 threads in the dome bush have partially stripped so I have made some studs and fixed them in with some loctite assembly. Hopefully they will hold.
Rich
Offline Firebird
  • East Midlands UK
« Reply #1027 on: December 15, 2019, 02:25:16 PM »
Hi
Got the dome refitted. The studs have held ok ish but I'm not 100% happy with them. The dome will have to come off again so I will look into a modification. Any future locos I build will have a much bigger dome bush with at least M4 threads
The good news is that under test the boiler held its test pressure of 1 1/2 times working pressure, 120psi.
So that proves that the ball valve regulator is letting pressure get by.
Back to the drawing board  :wallbang: :facepalm2: :facepalm: :( :'( :headscratch: :disappointed:
Rich
« Reply #1028 on: December 15, 2019, 02:29:59 PM »
May be worth checking the ball valve on its own with the test rig - one last (better) possibility is that the threads where it screws in leaked? I've had that happen, the fitting and bushing were fine, but just needed sealant on the threads.
Offline Firebird
  • East Midlands UK
« Reply #1029 on: December 15, 2019, 05:08:24 PM »
Hi Chris
Well I did check the ball valve on a very sophisticated bit of kit.
Because of the complexity of the test procedure I was unsure whether or not to post a picture  :thinking:
Seeing as it is the season of cheer, and I need cheering up, lets see who can come up with best caption
Rich
« Reply #1030 on: December 15, 2019, 05:13:05 PM »
The new bagpipe design proved to be just as hard to blow as the old one
Offline Steamer5
  • The "Naki" New Zealand
« Reply #1031 on: December 15, 2019, 05:14:26 PM »
Hi Rich...
And he huffed & puffed & went red in the face...…
Did it seal Rich?
On my loco the sniffing valve usually weeps a little until the regulator is opened, the it snaps shut, mine is vertical so not quite the same, I'd have to go back a bit to see if you posted up the building of yours but I guess its just a ball that seats when steam on.
Cheers Kerrin
« Reply #1032 on: December 15, 2019, 05:29:24 PM »
Hi Chris
Rich
Here is Rich wiuth his Steampunk Tuba....   :Jester:
Offline Firebird
  • East Midlands UK
« Reply #1033 on: December 15, 2019, 10:27:27 PM »
Hi
Kerrin, no it didn't fully seal. What you can't see in the photo is my hand in the smoke box with my finger over the exhaust. I could feel the leak. When I first tested it I could hardly get it upto 10psi before water was dripping out of the snifting valve.
I have a better quality ball valve I can play with when time permits.
Chris, not a very pleasant tune I'm afraid
Rich
« Reply #1034 on: December 15, 2019, 11:57:22 PM »
I doubt that.
I like that.  :Lol:
