Author Topic: Scale Model Bessemer Oil Field Engine  (Read 93725 times)
Offline AussieJimG
  • Bywong, NSW, Australia
Re: Scale Model Bessemer Oil Field Engine
« Reply #255 on: March 29, 2014, 09:24:56 PM »
Congratulations Chuck, I was sure your engine would run eventually.
It looks like you changed two things: the size of the transfer port and the change from pressure controlled to conventional porting.
The relative positions of the transfer and exhaust ports on yours look to be about the same as on mine so I guess my next move (after CF) is to increase the size of the transfer port.
Thank you for the experiments.
« Reply #256 on: March 29, 2014, 09:44:56 PM »
Congratulations Chuck. Great job persevering. Sounds beautiful!
« Reply #257 on: March 29, 2014, 10:16:42 PM »
Congratulations Chuck!  That's wondeful.   :ThumbsUp:  It runs great!  You should feel pretty good about that!
Thanks for posting the video!
Offline GailinNM
  • Albuquerque, NM, USA
« Reply #258 on: March 29, 2014, 11:41:04 PM »
Patience and persistence are two of model engineers most valuable talents.  You have shown that you have lots of both with this build.  Congratulations.   :ThumbsUp: :ThumbsUp:
Gail in NM
Offline Johnmcc69
  • Erie Pa., USA
« Reply #259 on: March 30, 2014, 12:31:37 AM »
 :whoohoo:
...what Gail said. It's great Chuck, you're an inspiration. Great runner!
Offline Doc
  • USA ND
« Reply #260 on: March 30, 2014, 02:06:10 AM »
ALL RIGHT CHUCK!!
 Way to go we all knew you'd do it.  :praise2: :praise2:
Offline NickG
« Reply #261 on: March 30, 2014, 02:53:09 PM »
Well done Chuck, and to think it was almost destined for the shelf!
Offline Alan Haisley
« Reply #262 on: March 30, 2014, 03:12:14 PM »
Beautiful sound, Chuck  :ThumbsUp: :ThumbsUp:
Alan
Offline cfellows
« Reply #263 on: March 30, 2014, 04:10:06 PM »
Thanks, all, for following the thread and keeping me going.  Still got a few things to do.
Although the engine will start, it's not running anywhere near as well as I want it to.  I'm thinking it would benefit from a second flywheel.  I have another casting like the original, so I'm going to clean it up and fit it to the other side.  I also need to finish out the cooling system and add a more permanent fuel tank.  Finally, I need to add top pieces to the crosshead slide.
Don't know if you noticed in the video,  but the engine will run equally well in either direction.  I'm planning to keep the glow plug ignition for that reason.
Chuck
Offline maury
    • Lone Star Engine Works
« Reply #264 on: March 30, 2014, 05:59:45 PM »
OK, chuck. Since you are going to use the glow plug and add a flywheel, why not just add a mock hot tube and put the glow plug in it?
maury
« Reply #265 on: March 30, 2014, 08:45:46 PM »
Hi Chuck, congratulation to this runner.
Offline cfellows
« Reply #266 on: March 31, 2014, 05:45:08 AM »
maury
There's an idea I hadn't thought of.  Actually, I haven't given up on the idea of an actual hot tube.  Might be about time for another field trip over to your shop and have a look at your hot tube.  The burner is still a it of a mystery to me.
Chuck
Offline NickG
« Reply #267 on: March 31, 2014, 07:15:56 PM »
Would love to see a real hot tube working! Like the fact that glow plug is working though as it is what I'll prob use on first ic. Are you just leaving the glow plug with power to it and running on petrol then Chuck?
