Author Topic: Quick way to cut a cam  (Read 6749 times)
« on: December 17, 2016, 12:11:49 AM »
I first seen this method of cutting a cam on a YouTube clip posted by Chuck Fellows. In his video, he attributes this method to Randall Cox. I have made cams using various methods, and this is by far the fastest method if you want a cam with a "flank radius" between the base circle and the nose radius. If you are using a tappet, the cam should have a radius on the flank as opposed to a flat.--Theory holds that if you have a flat surface connecting the base circle and the nose radius, that every time the cam revolves this "flat" will slap against the flat bottom of the tappet and cause a shock load, causing the tappet to bounce and lead to premature failure of valve train components. If you are using a roller tappet or a cam follower bearing then it is acceptable to use a cam with flat sides. This thread deals only with cams which have a radius instead of the flat. The attached drawing is of the cam for the Kerzel hit and miss engine, however the method can be used to cut any curved flank cam.
This is the link to Chucks video
https://www.youtube.com/watch?v=IEtqETL2LXs
Re: Quick way to cut a cam
« Reply #1 on: December 17, 2016, 12:12:38 AM »
In my drawing, the nose radius is 0.300", and the base circle is going to be .0.477". The cam blank which is the material I start with is going to be twice the 0.300" nose radius, which gives 0.600". This thread is not about how to determine all of the dimensions used on your cam. You are going to have to know that from a set of plans or from a complex set of calculations which will not be addressed here. The dashed line is the circle  which would be described by the "flank radius". The "flank radius" is, for all intents and purposes equal to the cam blank diameter. The cam blank diameter is 0.600, so the flank  radius will be 0.600, which gives the 1.2" diameter circle. We need this circle, because for our set-up in the milling machine, we have to know where the center of that circle falls.
« Reply #2 on: December 17, 2016, 12:13:17 AM »
I had to watch the video a number of times, and do a bit of head scratching to follow what Chuck was showing. It was complex enough that I had to make notes for myself to follow, and I will share them with you here.
#1--Center the rotary table under the quill of the milling machine.
#2---the mill must be set to run in reverse.
#3--the boring head which is used to hold the cutting tool must have the cutting tool turned 180 degrees to it's normal position in the boring head, so that it cuts on the inside of the circle as the mill runs in reverse.
#4--You have to have a  chuck (mine is a 3 jaw) mounted on the rotary table to hold the part which will become a cam, with the rotary table and chuck axis vertical
#5--Turn the boring head by hand until the  flat side of the boring tool is towards you with the tip facing to the right, just touching the tip of a pointed piece of rod of any diameter held in the chuck. Do not move the mill table while doing this. Use only the adjustment screw in the boring head. Use a Vernier caliper, and adjust the position of the boring tool (again using the adjustment in the boring head only--don't move the mill table) until the tip of the boring tool is a distance equal to the "flank radius" away from the tip of the pointed rod held in the chuck. (The flat side of the boring tool is still facing you--the adjustment of the boring tool is moving it to the left.)
« Reply #3 on: December 17, 2016, 12:14:03 AM »
Now we get to use the center of that dotted circle. Put the material from which the cam is going to be cut into the chuck and tighten the chuck. (the material must be pre-turned in the lathe to the "blank diameter", which in my case was 0.600"). Using the DRO or the dials on your mill table, move the mill table (from its  position directly under the spindle)  so that the center of the circle is directly below the center of the spindle. That is why we need the dashed circle--firstly to set the swing of our boring tool and secondly to pick up the x and Y coordinates to position the mill table.
Make sure that the bottom of the boring tool is at least 0.100" above the top of the material which will become the cam. swing the boring tool thru a full rotation by hand once to be sure it isn't going to crash.
Start the mill and very slowly lower the quill until it contacts the material. This will be the heaviest cut you take, so lower it very slowly. When you have reached the correct depth, set your quill stop if your mill has one. You will be taking many cuts to that depth. You will see that you have removed a strip of material from the left hand side of the cam blank.
Retract the quill, turn the handle of your rotary table one full turn clockwise, lock the rotary table, and take another plunge cut. This cut and all subsequent cuts will remove only a thin sliver of material.
Keep turning the rotary table one full turn clockwise between cuts, and plunge cut each time to the same depth. When you have worked your way most of the way around the cam, you will see the area which will be the nose radius of the cam getting close to the cutter. On the Kerzel cam, this width was 0.050", so at that point I stopped cutting and removed the material from the chuck. My material had been drilled and reamed on the lathe beforehand, so all that remained now was to put the material back into my lathe and part off the finished cam. My rotary table turns 4 degrees with each full turn of the handle, so it took slightly less than 60 turns and plunge cuts to completely finish the cam.  It goes very quickly.
« Reply #4 on: December 17, 2016, 12:14:45 AM »
Here are a couple of pictures of my set-up, and one of the finished cam (the one on the right).
« Reply #5 on: December 17, 2016, 09:38:27 AM »
It was actually Bill Wilkins who described the method in MEB #7 and that Randall Cox used in his popular Hoglet build.
Also be carfull using an imported boring head like yopu show Brian as the heads screw onto the shank and can unscrew if run backwards. Easy enough to grind up a tool for external cutting or use a holder and small HSS toolbit
Another thing is that the transition from flank to nose is usually rounded rather than the "edge" you show and this is termed the nose radius. The difference between your .477 base dia and the high point of the cam at 0.300 radius is the lift in this case being 0.062"
You can also take a series of cuts rather than have to make one deep cut at the beginning just make plunge cuts as you move the work sideways to the 0.279" position
« Last Edit: December 17, 2016, 10:08:30 AM by Jasonb »
ChuckKey
« Reply #6 on: December 17, 2016, 12:02:00 PM »
So, why is it usual to have a nose radius rather than a sharp shoulder?
Just as a flat cam flank on a flat faced tappet tries to create an infinite acceleration of the valve from stationary to maximum velocity in zero time, so does a sharp transition at the nose, from maximum velocity at the tip of the flank to stationary over the nose arc, again in zero time.
In simple theory the tappet would part company with the cam on both edges of the tip because the valve spring can neither stop the mechanism instantly nor instantly accelerate it to maximum speed down the closing flank. In practice (or more complicated theory) elasticy of the various parts comes in to consideration, and might or might not be enough to keep them all  in contact. The situation at the nose is less severe than with the flat flank condition because the change in velocity is down to the valve spring rather than being mechanically forced. Either way, a valve 'designed' to attempt instant acceleration is likely to be relatively noisy, and to suffer more wear than one that does not, and a nose radius allows a finite acceleration, giving a gradual reversal from from maximum upward speed to maximum downwards.
 A 'harmonic' cam, made of four circular arcs (heel, nose and two flanks) still has instant changes of acceleration. Rate of change of acceleration is called 'jerk', as experienced when your driver slams the brakes on or yanks the wheel over without warning. In the design of high-speed mechanisms, inculding cams, reducing jerk also produces smoother running, (but that would be going to extremes for a model IC engine cam).
« Reply #7 on: December 17, 2016, 02:32:10 PM »
A step which I didn't point out is that the sharp corner left where the cam flank transitions over into the nose radius should be filed carefully to give a slight radius, to avoid any really sudden transitions as the cam revolves against the bottom of the lifter.
« Reply #8 on: December 17, 2016, 03:40:52 PM »
I am getting questions on all 3 sites which I post on, asking if it is possible to use this method without running your milling machine in reverse, if you grind up a boring bar which cuts on the opposite side to my cheap carbide tooling. The answer is yes, I'm sure that you can, but you will have to try it and see. Some of the step by step procedures I gave in my instructions may be reversed, but then again they may not. Someone really has to try this and let us know.---Brian
« Reply #9 on: December 17, 2016, 06:53:52 PM »
Brian as I said earlier it can easily be done with the mill rotating as normal, either with the holder I showed or just regrind one of the brazed tip tools slightly to make the "curved" non cutting edge straight and away you go. It is also possible to buy "opposite hand" brazed tips that can be used for machining external surfaces and also in the horizontal hole in the head.
Not only does this stop the risk of your head unscrewing from the shank, it also stops any holding screw comming loose as Chuck mentions in his video
« Reply #10 on: February 05, 2017, 09:16:25 PM »
I took everyone's warning to heart, and cut my first cam with the mill running in the normal direction of rotation today. This made me spend a couple of hours sorting out a boring bar that would fit in my boring head and grinding an HSS cutter, but I persevered and managed to get a cam cut for my overhead valve engine. I thought about reversing the grind on one of my brazed carbide boring bars, but that meant the forces on the brazed carbide would be trying to pull the carbide away from the shank instead of pressing it against the shank, so I opted to grind a cutter from HSS instead. I want to shorten the boring bar up a bit because I was getting more deflection than I wanted, and then tomorrow I get to do it all over again, because I need two cams.
« Reply #11 on: February 07, 2017, 11:50:23 PM »
You can call me Two-cam-Sam!! There are a few things going on in this picture. The cam I machined yesterday just wasn't going to do it. I used the cobbled together boring tool on the left in my boring head to make yesterdays cam, and due to the long skinny shank it deflected enough that the cam surfaces were all slightly tapered. ------So, I made a new heavier, shorter boring tool with a newly ground HSS cutter in it, and made two new cams today. No deflection, and the new cams came out very accurately with no visible taper on the outer diameter. And yes people, the boring head would have unscrewed from the shank if I had been running the mill in reverse. The cams I had made prior to this, using the "boring head method" were mainly from brass, and presented no real challenge to the boring tool. These guys however, are made from 01 drill rod, and it was definitely a "thumping old time" cutting them. I'm glad that someone pointed out the error of my ways, and that I didn't suffer a catastrophe with the boring head coming unscrewed.
Offline Alan Haisley
« Reply #12 on: February 17, 2017, 06:49:04 PM »
Brian,
You suggest that using a bar that is too flexible caused a taper in the part. I have been hearing this since starting to read about model machining but have a problem with the idea. If you look at a diagram of the boring bar touching the part face, it is obvious that the deflection will to be the same all along the bore since the overhang of the boring bar doesn't change as the cut progresses. If there is taper in the bore, it must have another cause. Its possible that manual feeding of a cut could produce a taper if the feed rate varies, or perhaps the tool loses its edge as the cut progresses, but with a mill I can't come up with another way for it to happen. Its different with a lathe, since if the headstock is misaligned or if the chuck is crooked you are guaranteed a taper.
This bothers me since people keep using heavier or shorter bars and thereby eliminate taper when it seems as if this shouldn't be possible. Hopefully, people more crafty than I will chime in and discuss just what happens.
 :noidea: Alan
