The writer Marcel Proust was famous for reporting that one day he inserted a comma, and the next day removed it. He still managed to write some very long books. If you had drilled one hole and then plugged it the next day you'd be in a similar situation. As is is you've made considerable progress.
Modify the arch of the cap to make the flats longer. Then a small open end wrench can be used to tighten.
Hi SimonLooking good - Would you be willing to share the metric plans?CheersBruce
Hahaha I can relate to the sleep on it have had to do this myself a time or two.Good work looking good!
Arbor! That's the word I was looking for!Thanks MJM, when I was writing that post I knew there was a correct term, it just refused to come out "Excellent work"? Thanks, but I don't believe I deserve that accolade, this is my first build and the body (block?) is the single most complex part I've made to date.Perhaps reserve such words for the day I actually get this thing finished and, fingers crossed.... running!
