Author Topic: boxford rebuild  (Read 3302 times)
Offline kevin beevers
boxford rebuild
« on: December 15, 2016, 09:27:58 PM »
Just thought I would share a few photos of my Boxford rebuild I got this as a pile of bits dont know why its only letting me put one photo up
Offline RayW
Re: boxford rebuild
« Reply #1 on: December 15, 2016, 10:00:27 PM »
Hi Kevin,
Looks like your pictures are too big and that is what's causing the problem. Try re-sizing to, say, 800 x 600 max and try again.
Regards
ray
Ray
Re: boxford rebuild
« Reply #2 on: December 21, 2016, 01:35:28 AM »
Hey Kevin,    If you having trouble resizing them.....I can help.
Send me a PM ....we'll sort it out
Nice looking lathe!....
Re: boxford rebuild
« Reply #3 on: March 02, 2017, 02:00:02 AM »
Hi, the first thing i did with my Boxford after using a Myford for 40 years was to put the carriage handle on the "proper" side !! I found the B configuration quite difficult to use..........just sayin         good luck with it and i also used 1 1/2" whit worth nuts when i needed a quick backplate...
Offline Jonfb64
Re: boxford rebuild
« Reply #4 on: March 02, 2017, 08:42:39 AM »
That's a neat idea steam guy. Why do they put the hand wheel at the front were the hot chips drop? I ended up putting a handle on the tail stock end of the lead screw on my sphere atlas 10f clone because I got fed up with burning the back of my hand.
Jon
Offline Nick_G
Re: boxford rebuild
« Reply #5 on: March 02, 2017, 09:25:59 AM »
Hi Kevin,
I don't know if you have the drawings for your Boxford. Always handy to have if not.
http://www.boxford-software.com/spares/3656menu.html
In each section there is a diagram which is 'clickable' to make larger should you need them.
Nick
