Author Topic: engine identification??  (Read 4657 times)
Offline PJW
« on: December 09, 2016, 09:41:11 PM »
Hi, I picked this two cylinder engine up this week, can anyone identify it? It is made from castings so somewhere there may be some plans so & could try to complete it & get it running. Does anyone know anything about it??
Old Guys Rule the Dark Side of the Shed!
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
Re: engine identification??
« Reply #1 on: December 10, 2016, 12:08:27 AM »
That's a Seagull engine, by Etgar T. Westbury.
Plans and castings are available from Hemingway Kits.
Offline PJW
« Reply #2 on: December 09, 2016, 10:51:55 PM »
Thanks Yogi, it looks like I need two gears as turning the crankshaft does not operate the valves, I need a manifold & carb & something to give me a spark!
Offline PJW
« Reply #3 on: December 10, 2016, 11:56:08 AM »
Hi, has anyone built this engine or maybe has some of my missing parts to sell? I would love to see it running again or for the first time.
Offline PJW
« Reply #4 on: December 11, 2016, 11:18:56 AM »
Has anyone got any info on timing & engine rotation direction for the seagull engine please?
« Reply #5 on: December 11, 2016, 12:07:17 PM »
Peter,
Have you looked on the drawings? http://www.myhobbystore.co.uk/product/17487/seagull-pe25
« Reply #6 on: December 11, 2016, 03:25:07 PM »
Quite a bit of info in this build including correction sto the drawings/original ME articles
http://www.charleslamont.me.uk/Seagull/home.html
Offline PJW
« Reply #7 on: December 11, 2016, 03:43:17 PM »
Thank you both, I just have to buy the bits now!
Offline PJW
« Reply #8 on: January 31, 2017, 10:25:09 AM »
I have now done the gears & they are ready to fit but I need to sort out the valve timing, can any one help with information on this & engine rotation direction please??? :headscratch:
« Reply #9 on: January 31, 2017, 11:45:01 AM »
The valve timing is on sheet 2.
ChuckKey
« Reply #10 on: January 31, 2017, 01:09:54 PM »
It goes clockwise looking at the flywheel end. At top dead center, the cams are 125° (or 55°) either side of vertical (one pair pointing up, the other down). Note that the cylinder and crankshaft centrelines are offset, so strictly top dead (piston at highest point) is not when the crankpin is on vertical centreline.
Offline PJW
« Reply #11 on: January 31, 2017, 01:43:18 PM »
thank you for that, I didnt see the info on the bottom of the drawing 2, I have just been to the opticians, be glad when I can see again :old:
